Scorpion Race Series Roller Rockers
Old 11-22-2014, 07:25 AM
06vzssthunder's Avatar
Default Scorpion Race Series Roller Rockers
anyone used these before? they don't seem to be quite as expensive as some of the others that ive seem. thinking about getting a pair of the 1.8 ratio for my l92 heads.
Old 11-23-2014, 03:33 AM
or is it worth paying extra for the jesel rockers or any other brands?
Old 11-23-2014, 06:56 AM
Save the manuals!
wssix99's Avatar
Moving to Gen IV.
Old 11-23-2014, 07:11 AM
Jimbo1367's Avatar
They are probably rebranded. TRY searching for similar/same looking rockers and search there their reliability.
Old 11-23-2014, 07:20 AM
as far as I know thet aren't rebranded. I haven't been able to find out to much about them just seen afew threads here and there about then.
Old 11-23-2014, 07:22 AM
i was looking at the yella terras but ive seen quite a few people that have had problems with them and was put off from them.
anyone used slp rockers?
Old 11-23-2014, 01:10 PM
Briou's Avatar
I have a set of Harland Sharp 1.8 roller rockers I'm not using...shoot me a PM if you might be interested in them...they were used on the dyno but are still in new condition...
Old 11-23-2014, 07:17 PM
done alot of research and everyone says stock rockers with the bearing upgrade is the way to go so think i will look into doing that. anyone know if its easy to upgrade the bearings yourself?
Old 11-23-2014, 08:38 PM
Briou's Avatar
The trunnion upgrade is very simple if you have a pair of snap ring pliers, and a shop press....you could probably do it with a vice too, but I would highly recommend using a press....
Old 11-24-2014, 10:17 AM
Briou's Avatar
I'm running a set of stock LS7 1.8 ratio rockers with the comp trunnion kit, .700 lift cam and they are doing just fine so far...though the engine has only seen time on the dyno thus far...
Old 11-25-2014, 04:09 AM
Jontall's Avatar
Originally Posted by jim1450
There are a lot of trunion kits out there but for street use I'd stay away from most of them, the Summit kit even states not for street use.
The Harland Sharp kit uses a better material for the shaft but is probably the most expensive, I'd say the best of the others is the ones Brian Tooley sells.
I talked to Brian one time about his kit & I think they're better than the others, I'm thinking about trying his on my drag car.
Unless you need more lift out of a cam you already have installed I'd stay away from 1.8s, L92s with an offset rocker are bad enough & no need to make things worse with a bigger ratio.
His trunion kit looks exactly the same as the (Comp) other brand kits, it's a few dollars cheaper though...
Old 11-25-2014, 09:20 AM
Briou's Avatar
If I had to guess I'd say it was the same kit, just rebranded...
Old 01-05-2015, 10:29 PM
soundengineer's Avatar
Scorpion rockers are great...
they are not rebranded... they make them themselves.
we have used them on several engines...
they fit under the valve covers without having to clearance the heads or the covers
and they work well.
Old 01-05-2015, 10:37 PM
Briou's Avatar
Just to clarify I wasn't saying that the scorpion rockers were rebranded...I was referring to the trunnion upgrade kits...
Old 01-08-2015, 04:37 PM
Gray86hatch's Avatar
Stick with stock rockers.
Tim
Old 01-14-2015, 01:44 PM
csequipmentsales's Avatar
Default Personally
In my opinion(and I'm sure most would agree) Comp, Crower, or Jessel shaft rockers are worth every penny.
I use Crower.
Old 01-14-2015, 02:01 PM
The Scammer Hammer
dr_whigham's Avatar
Just to put this out there:
Brian's trunion upgrade kit is actually of a better quality steel than the kit Comp makes and sells. Kip at Cam Motion or Brian himself can chime in and back up that claim.
If I do a trunion upgrade again, it will most definitely be with Brian's kit.
Old 01-15-2015, 09:21 AM
Briou's Avatar
What is the difference between the Comp kit and the BTR kit?
Old 01-15-2015, 09:38 AM
The Scammer Hammer
dr_whigham's Avatar
The quality / grade of steel used to make them.
Old 01-15-2015, 10:22 AM
Briou's Avatar
Hmm that is very possible...I wonder what the results would be if you did a metallurgical analysis on both kits...just to see how different they actually are...
Now I'm not saying that they aren't different, or that anyone has made any false claims, but I can't help but question the validity of this....
Quick Reply: Scorpion Race Series Roller Rockers
