Titanium Valves? Mast 305cc vs. PRC 285cc LS7
Hello all,
I am trying to decide which set of cylinder heads I am going to run in my ERL 454ci build.
It will be a solid roller system targeting a 7.5k RPM red line. Most of the engine's life will be spent between 4-7k on the track.
The titanium valve upgrade through Mast is a skull crushing $800 on top of an already steep entry price. With their solid roller setup the price tag starts creeping up towards $5k, which just seems prohibitive for me.
The PRC 285cc heads have a $400 adder for the titanium valves and it seems like I could get those assembled with the correct springs and on my doorstep for under $3,500, which is still steep but more reasonable given the flow numbers they claim.
I would just like some feedback on how important going Ti will be in either heads at the RPM levels I'm shooting for and any take on the respective heads.
Also would be open to hear of other equally performing heads that would come in cheaper with Ti valves and ~.750-.800" lift beehive spring setup.
All appreciated!
All appreciated!
TSP had good reviews/power on LS7 head swap a mag did a few years ago. If you call TSP, they might be able to e/m you the article or at least let you know what magazine and date of the issue. I remember being impressed their head did so well.
I also agree with Grey86hatch about the quality of ti valves.
Does going solid roller vs. hydraulic reduce the overall benefit of going with Ti valves due to the reduced weight of the valvetrain?
Currently leaning towards the 305cc heads without the valve upgrade. Using the Mast solid spring option I might get out the door around the $4k mark which would keep me happy.
Do the Mast castings already have provisions for shaft mount rockers? It looks like their rocker stands are for pedastal (stock) style rockers.
I'm going to run the Crowler LS7 shaft rockers so I would have to add that cost to the PRC heads, I imagine.
I would call everyone and kick over what you are running in your combo. Call TSP, Mast, and maybe WCCH a ring too for reference.
The Crower rocker LS7 setup is 1200 roughly IIRC. Youll have to check each head and see how each one is set up out of the box.
This is raising the cost of the heads considerably but they are definitely where all the power is sitting in this build so I'd rather wait a few months longer and have it correct out of the gate. This engine is going into a 2 year project car so I can handle the wait!
Mast also offers inconel exhaust valves but I don't have much information on them. Any comments on those?
Thanks for all the input, everyone.
With the mast heads and a large diameter, High pressure springs stainless valves are fine..
You aren't spring limited like on stock ls7 heads. So the valve weight thing isn't as big of a concern in my opinion.
Thanks!
Both valves would be fine being SS or just the smaller exhaust valve, in your opinion?
His stuff looks incredible and he is absolutely on the list I just haven't seen any prices so I figured it was north of Mast.
Great points - Mast offers an inconel exhaust valve but no hollow stainless options that they show online.
Thanks!
Thanks!
Both valves stainless should be fine is my opinion.
And it is also the direction I decdied to go with my build.
2.2 diameter valves and some big Manley Springs. 1.55 diameter. Solid roller stuff
My car just got done, ERL 434 M2 bottom end and PRC 285's with a ported stock LS7 intake. Made 575 / 505 thru the LS7 intake, cats and 1 3/4 headers, 66-67 chambers I believe.
