LS2 & LS6 Interchangable Parts
Old 12-20-2014, 09:07 PM
LTX_Alex's Avatar
Default LS2 & LS6 Interchangable Parts
Between the LS2 & LS6, what parts are Interchangable & what aren't? (Like the crank in particular) Thank you.
Old 12-20-2014, 10:08 PM
KCS
Moderator
KCS's Avatar
Pretty much everything but pistons and rings.
Old 12-21-2014, 09:36 AM
Mercier's Avatar
Look up crank reluctor wheels..they will technically work in either block but you need the right wheel for the computer you plan to use. Knock sensors need attention. Cam sensor/front cover is different though does interchange. Cams are 3-bolt vs. 1-bolt right? Just have to match up the right sprocket, cover, cam sensor to make it work right depending on which direction you go.
Quick Reply: LS2 & LS6 Interchangable Parts
