Finally! Isky Hydraulic Roller W/Bushings No Needle Bearings!
Location: Coast of San Mateo County Between Pacifica & HMB
PRI Show Stopped @ Isky Booth asked when they were going to make
LS Hydraulic Roller with there Bushing, Like their Solid W/Out needle
Bearings!
They said NOW! It's out, I saw it and they even had promo material.
There might be only one other person as excited as me but I think
He couldn't wait and went Solid!
Anyway pretty expensive!
Bearings!
Yeap , I knew they were coming think I talked about them this summer they took a little time but there here. Cost is what will kill most, 1grand or 1000.oo US dollars. I'm just going 2 stick with this EZ roller solid setup, I may get them 1 day long from now Chi heads are on lay-a-way & a dart block is needed.
Along with the bushing bearings, you must use the axle oiling option (that is what Isky is using). Without the extra oiling...which increases cost...there isn't enough oil to dissipate the heat, causing premature wear to the bearing.
These are made by Johnson Lifters with Isky's patented EZ-Roll bearing. They are only available through Isky at this time.
