Need Help 410 stroker
Well I just bought a 410 stroker longblock from a friend and have most of the specs on the motor but one of my questions is the cam and heads..The longblock was Built by Thunderracing (no longer in Business)and was Built to RUN..
The Cam was Custom from ThunderRacing 251/259 660/663 lift @112
would there be any sites to compare to this cam?
Heads are GTP stage 3 862's also FAST 90 but flow sheet shows 309cfm @600
What fwhp should this motor make?
Thanks
Sean
Thanks
Sean
Heads are what kill that engine also to much duration very favorable towards top end and a Fast intake stalls well before your cams intended max rpm.
But over 500 easy.
The reason on the heads is flow is more than likely maxed @ 600 lift, wear as the cam goes up past 650.
But over 500 easy.
But over 500 easy.
But over 500 easy.
What Heads should I use? Do I go with a FAST 92?
