800hp LS3 Parts Requirements
Within the next month, I will be getting a new LS3 shortblock capable of 1000+hp but I'll only be pushing 7-800 at the start. I'm curious to know what would be recommended or required for the various parts other than the rotating assembly. I'm looking like lifter, rocker arms, timing chain setup, flex plate, pushrod thickness, ect.
How much you wanna spend? Cause you can use shaft mounted rocker or just buy stud mounted rockers,3/8 pushrods or heavy walled thinner ones....etc. or some good Morel lifters or bushed lifters on and so on. Also how big is the motor, N/a higher rpm or a lower rpm F/I build. Cause 700fwhp or 800fwhp adds up to either one of the ?"s in the last sentence.
Choosing the correct parts on the front half and being aware of their cycle life in their new found high horsepower usage is key. Give us some insight on the total package and we can assist you.
Which magancharger are you running? Do you already have it? I drive my ctsv around every day making 710whp thru a 6l90 and then spray it to 970whp. I've only sprayed about 80 bottles thru it. You don't need anything crazy, stock rockers, med size cam, don't build a stroker motor, 9.5 compression at least, e85 or meth injection.
Build is as follows (so far):
This all makes for about $7700 if purchased from one place since I haven’t searched for cheaper. Anything else I should look into or that yall would change?
- TMS LS3 (stock displacement)
- New GM crank
- Scat I-beams
- Diamond -15cc pistons
- Melling oil pump
- King Racing bearings (rod and main)
- Arp rod bolts and main studs
- Heads
- Manley SS valves
- Ported intake, exhaust and combustion chamber
- Milled 0.030
- Cam - Still determining the grind (suggestions? Want blower friendly but lopey)
- Morel Linkbar lifters
- 3/8th pushrods (length TBD)
- Dual spring kit (depends on cam lift)
- Comp Trunion upgrade
- ARP head studs
- LS9 Gaskets
- ID850 injectors (possibly DW instead)
If your goal is 1000 HP, forget the Scat rods and GM crank. Start looking at Oliver, Carrillo, or Crower rods and a Callies, Lunati, or Crower crank.
You might want to look for an LS9 block as its has several upgrades designed for boost. There are some used ones for sale fairly reasonable.
The next thing to consider is the cars drive train. It will need considerable upgrades.
Good luck!
Good luck!
Specs on it is everything above but
- TMS 4340 Forged H-Beam Connecting rods
- TMS/RPM 4340 Forged Crankshaft
As for cooling, Ive already got a new heat exchanger and Ill be making a 1.5 gal reservoir. Probably going to go with an LS9 pump to replace the magnacharger pump and maybe some internal cooling mods to the maggie itself. Other than getting a super chiller that attaches to the AC, not much else can be done.
