RHS head question. 54500. Port specific
Been looking at these for a while now. Thinking about pulling the trigger but there is one bit of info i cannot find the answer on.
Title says RHS ls3/ls7 heads. but on RHs website it says ls7. Can these heads been used with ls3 intakes or is it strictly a ls7 head. This head will be ported to match my motor along with chamber and all. Looking for around 420cfm if possible with a holley hi ram. but was looking at a few ls3 manifolds.
RHS#784-54500
Pro Elite Cylinder Head
GM LS3/LS7
Bare Head
Without Valve Job
http://www.jegs.com/i/RHS/784/54500/...ductId=1794708
RHS#784-54500
GM LS3/LS7
Bare Head
Without Valve Job
Ls7 intake for Ls7 heads. They sell a Holley high ram for the Ls7. Here's who you need to get the cfm that your requiring...
Big FRH port 306.5cc 2.250 intake valve and 1.600 exhaust Valve
Intake Flow
.200/160
.300/244
.400/310
.500/365
.600/393
.700/411
.750/420
We also offer a solid roller head that is 308cc that has a 2.250/1.600 valves that flows 438cfm on intake and 269 on the exhaust @.820. That head has Ports designed for high rpm and bigger camshafts. It also has a 50 degree valve job.
I hope this helps you on head choices. The rhs casting is a good choice for sure.
__________________
FRANKENSTEIN RACING HEADS
817-556-2434
FRANKENSTEINRH@gmail.com
Intake Flow
.200/160
.300/244
.400/310
.500/365
.600/393
.700/411
.750/420
__________________
817-556-2434
SO here is the question then. What would you guys put on the motor for head? 350 cubes. 4.185 bore, 3.185 stroke. aluminum rods. 12:1 compression @50cc combustion chamber. Solid roller cam on race gas. I will be going with jesel belt drive/ front distributor combo. Hi ram intake with dual carbs. Pistons are flat tops 2 valve releif coated and so on.
