Boreing a GEN4 block to run a 60mm Camshaft
Hi All,
Has anybody successfully over-bored the cam tunnel on a GEN4 aluminum block to take a 60mm camshaft?
Obviously a larger diameter much stiffer camshaft core than standard is highly desirable for a high revving road race engine, so if anybody has been down this road before I sure would appreciate hearing from them.
Cheers,
Mark.
Cheers,
Mark.
Appreciate your thought's HD, however, this engine has to run at least 5,000 miles over 6 x 3 hour races, and is competing against Factory backed Ferrari's, Mclaren's, Porsche RSR's etc, so it has to have at least 750BHP and still be ultra reliable.
If you think we are "way over thinking" our build you should see the extent GM go to with their Daytona Prototype engines, just their billet block alone is $12K, and god knows what their billet cylinder heads cost!
We are trying to bring this engine in on budget [$40K] and still have a very stout reliable engine into the bargain, which is why I don't want to risk running the 60 mm diameter cam unless its been well proven in a standard LS block.
If I don't get any positive feed back from the various enquiries I am making, including raising the question on this forum, then we will settle for the standard 55 mm diameter cam.
Cheer's,
Mark.
Cheer's,
Mark.
Cheer's,
Mark.
Cheer's,
Mark.
Call SAM (School of Automotive Machinists). I'd be willing to bet the Massengil fellas have done this as well as the keyed 1" bore Jesel lifters. In order for them to be making well over a thousand NA horsepower out of a 436 inch engine, surely they're pulling out all the tricks.
Texas Speed guys may have also played with this idea as you would be removing roughly .100" material to open the cam bore around .200"
