No vacuum port on LS2 valley cover?
I just purchased a valley cover from a forum member and there is no Vacuum port on it?
I'm switching from an ls6 to and LS2 and I knew I needed a different cover.....but don't I need the port?
Looks like it can easily be drilled/tapped and added, but then I don't have all that fancy PVC plastic apparatus that goes in the valley to keep oil out.
So did I get the wrong cover? Or what are my options?
Thanks!
Thanks!
It is an LS6 caddy, getting an LS2 406 installed. Collecting parts currently, and got a valley cover with out a vent so I was curious for what I should do.
That is good news, I appreciate it.
Any pictures showing how you have the crank case ventilated or do you still use a pcv?
I'm curious how I should run mine. It is NA for now and mainly a street car with the occasional track day.
