Good Radiator
Good Radiator
I'm wanting to replace my stock radiator that I have in my '99 TA. I am currently running about 600 hp LS7. Does anyone know or refer a brand radiator? I'd prefer direct bolt in.
Thanks!
Thanks!
Why do you want to replace? Run hot?
If so, have you considered a just using an LT1 f body radiator? If you didn't know they are about 25-30% thicker in the cores than the LS1 rad. Drop in and instantly solved my heat issues. Texas summer with the a/c on in a traffic jam and it holds my 416 stroker temp perfectly.
Best part is it's only like $125 new from Autozone.
Search around and you'll see lots of guys have had success.
