Jesel cam cores? Anyone?
Been looking for info on these but cant seem to find any. Jesel is local to me and ive been interested in these for a while but cant see any info on anyone who has used them. Im needing a cam for my build and was interested in having one designed then cut from one of these cores. Anyone have any info?
I am looking for a solid roller cam, 60mm core for a dart next block N/A build. Track motor max effort. Also will be using .937 diameter lifters with .850 roller wheels.
http://www.jesel.com/valvetrain/index.php/cam-cores
You would need to call Jesel to see if they have cores available for a 60mm LS engine. I have not ground any LS cores Jesel made. I do not think he has made any for the LS but I could be wrong. I know they can make any core from a print. We have 60mm 8620 cores in the round stage available for custom profiles that can be milled to your spec's then heat treated and finish ground.
