what do you guy recommend for my setup LS3
I have 2010 Camaro ss m/6
currently the car is bolt-ones with a stage 2 monster clutch and I wanna good head cam setup
Setup
injectors 42lb High-Z Flow-Matched 8PK from racetronix
Fuel pump 340 Stealth In-Tank Fuel Pump - Offset from aeromotive
Fuel pump A600-A Flow Through Fuel from Weldon
Fuel Pump Aeromotive A1000 Camaro Stealth Kit
Texas Speed LS3 235/239 .627"/623" 3-Bolt Camshaft
but the thing is I don't know what LSA shell I pick and I have no idea what push rod and spring that would be suitable for the stock heads
Melling High Volume Oil Pump
Texas Speed Ported LS6 Oil Pump w/ O-Ring
I think more of melling for oil pump
if you guys recommend anything in top of that please let me know what good alternative setup I can have for maximum N/A HP in a stock block
O2 wire and oil filter and other basic stuff I am already covered about that but I had one issue of the gasket can any one support me with that as well.
thanks.
Setup
thanks.
Salam Alykooom Mullahi,
- Pushrods : you need to measure. (Utilize comp cams pushrod checker tool)
- Springs : I would recommend BTR. Contact Brain Tooley ( braintooleyracing.com ). The guy will set you up with high end spring/retainer kit.
Regards,
Regards,
I checked the Springs website that was really helpful thanks man
I have 99 like urs with same basic setup ;p
