Shortening LS7 Crank?
Hi All,
I'm using the LS7 factory crank for my 418" stroker. TPS says they're "not equipped to shorten the crank" and suggests using the Scoggins-Dickey spacer over the front of the snout to keep the pulleys lined up. That looks like another $70 for the spacer and ARP LS7 crank bolt. I'm thinking about using my Portaband saw to remove all but a 1/16" or so of the needed amount (1.00" ?), chucking it in my lathe, and smoothing off/chamfering the cut end. Of course, I'll measure everything against a standard LS crank first. Anyone foresee a problem with this?
Are there any other concerns, like thread depth, etc? If I can "Portaband" off excess on the snout, I could do the finishing in my old Atlas lathe. Hell, I could prolly do the whole cut with a parting tool but it would be slow going...
Recently I saw someone selling a shortblock at his machine shop with compstar LS7 or Eagle std LS crank; I thought take the LS7 crank all day long. Gives you more options for resale.
The following users liked this post:
64post (03-08-2022)
My only concern with any thing band saw like, the blade will be deflecting like a ****. If that's not an issue it should be ok.
Did the chop job this afternoon, came out great. Gotta say, it was rather harrowing to have a $1k, 55# chunk of metal spinning in an 80 year old lathe that was, in all respects, a tad too small. Had visions of it jumping out and landing on the concrete floor. I hacked off 0.875" with my Portaband saw, then stuck the crank in the lathe. I don't have a steady-rest, but do have a good quality live center for the tailstock. Tried partially screwing an old (center-drilled) bolt in the crank snout, but there was enough play that it was wobbly. Had to make a bushing "shim" for the bolt neck from 0.030" aluminum stock, that cured the wobble. Then I had to neck down about 3/4" of the bolt under the head to around 1/2" diameter so there would be room for my carbide bit to get access to all of the face. Faced it so it ended up a total cut of 0.900", then an outer chamfer. Had to do the inner chamfer with a 1" drill bit in a hand drill.
HTH,
HTH,
Just pay the 70$ for the spacer. The outer diameter is for a factory ballancer so i had to have a local machine shop take a little off the outer diameter for my ati pulley but i found it a much better option then trying to chop off the snout and in the future i can always go dry sump
LS-7 = Lite Rod Crankshaft
WARNING : The LS-7 crankshaft is a fine piece, great for LS-7 oil pump, front cover, and oil pan.
This item IS balanced for Titanium rods, lite rods.
The cost of a balance job with Heavy Metal for use with steel rods may be over $600.00.
Many suppliers offer a 4.00"/4.10" Forged Crankshaft, standard LS crank snout, 1850 Bob weight for a small increase in cost over the balance cost of a LS-7 using steel rods.
Another feature, if rods and piston weights are matched, is a crank balance may not even be required.
Most here know Bob Weight may be greater just not less than the requirement. (Overbalance)
Lance
Lance
Lance
Lance
I ran Lunati ProMod rods with an LS7 crank and the mallory needed to balance it was around $500-600 balance job like you said. Those Lunati rods were rated at 1500hp or so and waaaaay beyond the limits of my block. It did work though
Of note- if you want the snout cut it is about equivalent cost to using the spacer..... and you better find a quality machine shop. I had it done on an LS7 and LS9. A shop in SoCal cut them and it worked out great.
