More LS2 info... Parts are compatible...
#42
Originally Posted by 427
The 90mm FAST throttle body is a bolt on to the LS2 manifold.
Kurt
Kurt
#43
i want to know also.. does anyone have a definate answer..
Would an LS2 intake manifold work on a LS1.. and can you use the 90mm LS2 throttle body or would you have to buy the FAST Throttle body? (any other options for TB) thanks
#44
#45
Originally Posted by Ravenous T\A
I work at a GM dealership, I checked the part #'s from another thread and I can order the intake now, but I wanna make sure It will fit on an LS1 style motor?
So Ravenous do you have a price for the LS2 intake?
#46
Originally Posted by LS1BlackZ28
I'm guessing the C6 LS2 TB will be fly-by-wire so it won't work for us unless the future GTO or SSR LS2 uses a throttle cable.
#47
6600 rpm clutch dump of death Administrator
but will the ls2 intake work if you use the FAST 90mm TB??
As for bolting up to the LS1, the heads I saw the intake bolted to were ls6 castings, so, they should bolt up to any ls1 with no issue.
#49
Well the pricing I have from GM is get this $357.86!!! thats cheaper then the LS6 Intake, but I was told price may change, I tried to order one but they said they are not available yet, but I am gonna keep trying. I just hope the price stays there.
#50
I talked to Myron Cotrell at TPIS a couple weeks ago in Indy, and he also stated that his 90mm throttle body would bolt up to the LS2 intake.
If the LS2 intake is indeed in the $400 range, that would be awesome. I'll give Myron my money for the 90mm TB, and get the LS2, and call it good. The TPIS TB is a very nice looking piece, btw... if you're in the market, check 'em out.
#51
Can you give me the part number for the LS2 intake? Me and my brother are both wanting the new intake. Thanks for your help.
#56
What is the SCCA CTS-V running? I thought it was an LS2. Its intake manifold is listed as part number 12569011 with a 90mm opening...
http://www.speedvisionwc.com/competi...CTS-V-REV1.pdf
#60
Anybody have any idea when the LS2 intake will be released? By the looks of things the C6's are starting to surface. I am sure it is wishful thinking that the intake will be cheaper that the LS6.
Thanks,
Dave
Thanks,
Dave
