More LS2 info... Parts are compatible...
Old 06-04-2004, 12:38 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Default More LS2 info... Parts are compatible...
LS2 and C6 info
http://www.crossedflags.com/nuke/htm...wtopic&t=10796
This info came from Josh Holder who is on the Corvette team...
Some basic stuff about the LS2...... It has the same stoke as the LS1/6. The bore size has been increased to 4.00" and the cylinders are siamesed. The block is very similar to the LS1/6 from the outside. The mounting points and bellhouse patters are the same as the C5. The big external change is the oil pan. It doesn't have the "wings" on it like the C5. GM has determined that the wings aren't needed. Now, for the really big news....THE BLOCK WILL DIRECTLY BOLT INTO THE C5. THE C5 HEADS AND MANIFOLD WILL BOLT RIGHT ONTO THE BLOCK. The PCM is different, as well as some of the other stuff, but the LS2 block can be easily used in the C5. Can you say cheaper C5 stroker motor Josh confirmed this info before he came to MT.
LS7 info:
http://www.crossedflags.com/nuke/htm...ewtopic&t=7728
Old 06-04-2004, 12:40 PM
Shorty Director
VINCE's Avatar
This is good news..
Old 06-04-2004, 12:41 PM
FEAR THE LS1's Avatar
Ahh Good Stuff!
Thanks!
Old 06-04-2004, 12:45 PM
Adkoonerstrator
XLR8NSS's Avatar
Siamesed bores....so how big a bore can this sucker support?
Dumb Ass Vette Moderator
ls1290's Avatar
I wonder if the LS2 block will have a 0.010" overbore limit like the LS1/6 blocks?
Old 06-04-2004, 01:21 PM
taqwache's Avatar
what about the LS7 head? will it be interchangable in anyway?
Old 06-04-2004, 01:33 PM
OWENMUSTANG's Avatar
thought only 97-98 blocks have that problem..newer blocks .020
Old 06-04-2004, 01:36 PM
Adkoonerstrator
XLR8NSS's Avatar
A part number and the max overbore is all we need to know now.
Old 06-04-2004, 01:53 PM
Scalpel's Avatar
No joke, this is awesome news.
Old 06-04-2004, 03:38 PM
WILWAXU's Avatar
O yeah! Drop in 6ltr
Old 06-04-2004, 03:44 PM
Boosted LS1's Avatar
Does anybody know if the bores are siamesed at the top where the cylinder is hottest or just most of the way up? If siamesed all the way will there be cooling issues?
Old 06-04-2004, 03:46 PM
Bad30th's Avatar
...and a price from SDPC !
This is stellar news !!
Bad30th
Old 06-04-2004, 03:54 PM
CHRISPY's Avatar
Great news!! AFAIK the heads are LS6 casting but I am not positive.
I'd like to know more about the intake and throttle body setup
Old 06-04-2004, 04:26 PM
Mike K.'s Avatar
Damn thats awesome.
Old 06-04-2004, 06:13 PM
someday's Avatar
its an aluminum 6L block, it will also be used in the upcoming 385hp version of the 6L used in the silverado ss, the trailblazer ss, the ssr, and the gto... it will also be called an LS2, just detuned a bit...
Old 06-04-2004, 06:16 PM
BADFNZ's Avatar
So if the LS1 intake and TB will fit on the LS2 block, does that mean that the LS2 intake and TB will work on the LS1 block?
Old 06-04-2004, 06:19 PM
mrr23's Avatar
heads are ls6 castings ported. has 2.00/1.55 valves. the intake is 90mm and has a 90mm TB. the new 6.0l is 15lbs lighter than the current ls1.
Old 06-04-2004, 06:30 PM
BADA BING BADA BOOM!!!!!!
Richie Carbone's Avatar
What about the location of the crank and cam position sensors????
Old 06-04-2004, 06:37 PM
mrr23's Avatar
i do know they have moved the knock sensors from under the intake. not sure of the others.
Old 06-04-2004, 07:22 PM
BADFNZ's Avatar
So will the LS2 intake bolt on to the LS1 block? Might gives us a few more intake options in the future.
Quick Reply: More LS2 info... Parts are compatible...
