New Longblock being Stored
Old 06-23-2015, 10:03 AM
my bandit's Avatar
Default New Longblock being Stored
I have a new complete longblock that I purchased but it will not be ran for at least another 4 months. Is there anything I should do to it or can it just sit? It has never been fired and was assembled with assembly lube.
Old 06-23-2015, 06:55 PM
Jimbo1367's Avatar
I've had good luck just fogging the motor through the plugs with Kawaski 4 stroke jet ski fogging oil. It has great atomization. I'm sure some will just suggest WD-40. Since you have the cam in, I usually loosen the rockers to seal the combustion chambers.
If you want to be ****, try prelubing too. I prefer to use the smaller oil sensor port in the back of the intake. It may take a little longer, but you won't leave a big mess when removing lumber. line. This should also reduces the air let back into the system since its smaller and higher than the normal ports.
Old 06-23-2015, 10:41 PM
Fraser588's Avatar
What he said.
If you want to get extra ****, bag it up, put a few desiccant baggies inside of the plastic with the engine, tape the openings shut. Wicks up any moisture.
Desiccant bags, Uline, grainger etc. all sell them.
Old 06-24-2015, 07:40 AM
Bowtie316's Avatar
I have used wd-40 in the past with poor results in KS humidity. I now use break-free clp. Its gun oil designed for the military to Clean, Lube, and Protect and won't dry out as fast as wd40. A couple squirts in each cylinder, rotate the crank a few times, install some dessicant, and bag it up.
Quick Reply: New Longblock being Stored
