Which first? Wipe pattern or pushrod length?
Brand new motor, just got it together. I know how to do both but realize that changing the wipe pattern VIA machining/spacing the rockers (yella terra) that it will have an adverse affect on the push rod length.
Thanks for any help!
If the wipe pattern is important to you check that first sense if you need to shim that will alter the push rod length.
Ideally the wipe pattern be at center but a little off is normal and I personally leave it along never had any problem that's what the stem lubrication is for and take care off.
So I guess I should clarify, I have no push rods available currently. The idea was to wait until I knew what length I need. At this point I'm just hoping I get lucky with the wipe pattern. Measuring push rods is easy, and can be done quickly. So I'm going to order what I have measured then pray the wipe pattern is good.
You need a pair of lightweight checking springs.
The imaginary line that connects the center of the rocker arm trunion to the center of the roller tip of the rocker needs to be perpendicular to the valve centerline when the valve is 50% open (roughly .300 retainer movement).
The checking springs should not collapse the lifter plunger and then you can just add your desired preload to the measured checking pushrod.
