URGENT! Oilleak from crankshaft to flywheel??
Old 08-02-2015, 06:46 AM
LS32GO's Avatar
Default URGENT! Oilleak from crankshaft to flywheel??
Hey all,
we are running a built LS3 based stroker engine.
A couple of events ago it started leaking oil so we dissembled the gearbox and the flywheel, as we thought it might be the rear crankshaft seal. After removing the flywheel there was quite some oil in the middle of the crankshaft. We realized that there is some kind of plug.
Can anybody give us some advice on what might be the problem - the car has to be up and running in 3 days .
Thanks in advance for your help!!!
Attached Thumbnails URGENT! Oilleak from crankshaft to flywheel??-img_20150801_214909.jpg   URGENT! Oilleak from crankshaft to flywheel??-img_20150801_214914.jpg   URGENT! Oilleak from crankshaft to flywheel??-img_20150801_214933.jpg   URGENT! Oilleak from crankshaft to flywheel??-img_20150801_214937.jpg
Old 08-02-2015, 09:10 AM
LS32GO's Avatar
Originally Posted by LS32GO
Hey all,
Guessing this is the problem: https://ls1tech.com/forums/generatio...g-leaking.html
What kind of silicone do you recommend for this?
Old 08-04-2015, 09:58 PM
DietCoke's Avatar
Silicone? You've got jokes.
Green loctite.
Old 08-05-2015, 03:16 AM
03EBZ06's Avatar
We had to tack weld the reluctor and fix that on my Callies crank. Amazing they have such a good rep.
Quick Reply: URGENT! Oilleak from crankshaft to flywheel??
