NEED HELP!!! Which oil tube pick up oring to use?
I'm changing the oil pan/pick-up tube on my LY6 6.0 to a 2007 Cadillac CTSV oil pan/pick-up tube. The pan and pick up tube i got didn't have an o-ring when i got it. I hve RED o-ring that was on the truck pickup/oil pump but after looking it says the Cadillac pick-up tube should have been a BLUE o-ring. Im thinking i should use the red one since it was what the original seal the truck oil pumps come with. I need to make sure I have the correct one because I don't want to have to change it out after I install the engine (or even worse damage the engine). Any suggestion would be helpful. TIA.
Unfotunitly when i got the pan and pick up tube it didn't come with instuctions or with an oring. i just know i have the red one that came off my truck pick up and figure i should use the one for the pump but im not sure? Looks like ill be going to the Gm dealer tomorrow for an oring.
Thanks S10xGN. Reading comprhention exceeds me today at first i read your posts wrong but i found that the pumps are the same bore and the oring needs to match the tube. Thanks again sorry i read your post wrong.
