“Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
Old 10-29-2015, 05:02 PM
  #41
AINT SKEERED's Avatar
Id love to replicate but since i have an iron block i want to punch out .070 over for a 416 or so. Those heads look very promising
Old 11-01-2015, 08:46 PM
  #42
Project GatTagO's Avatar
Received 1,391 Likes on 879 Posts
Nice job Steve!
Also, it was nice meeting you at LSFest.
Andrew
Old 11-02-2015, 06:20 AM
  #43
Lawhead's Avatar
Shot you a PM about the heads speedtrigger these look very interesting
Old 11-02-2015, 07:57 AM
  #44
Old School Heavy
speedtigger's Avatar
You could replicate on every other part and make even more power with the extra cubes.
Nice job Steve!
Andrew
It was great to meet you too Andrew. Everyone loved the old school machismo of your Cougar.
Got it. Your new build is going to be a monster.
Old 11-02-2015, 10:35 AM
  #45
Lawhead's Avatar
It was great to meet you too Andrew. Everyone loved the old school machismo or your Cougar.
I really hope so man on paper it should be stout but let's see how reality treats me lol
Old 11-02-2015, 07:53 PM
  #46
Old School Heavy
It is in the car:
Here is what the idle sounds like without the exhaust installed:
Old 11-02-2015, 08:14 PM
  #47
blk00ss's Avatar
Wow. That sounds awesome.
Old 11-02-2015, 09:11 PM
  #48
SHovV's Avatar
Sounds killer!
Old 11-03-2015, 01:25 PM
  #49
A.R. Shale Targa's Avatar
Nice crackle.....love the circle track style air cleaner. Should put it down nicely.
Initial passes NA In the 10.27-10.33 range @ 130.79.....intellectual guesstimomiter
Old 11-03-2015, 01:39 PM
  #50
Tuskyz28's Avatar
That's go get people attention !!
Old 11-03-2015, 04:03 PM
  #51
Millenium Z06's Avatar
Damn, that was quick!
Old 11-03-2015, 07:33 PM
  #52
KCS
Moderator
KCS's Avatar
Sorry if it was mentioned already, but what was the lash set at? I would think with an aluminum block and heads, it would be pretty tight.
Old 11-03-2015, 09:21 PM
  #53
Old School Heavy
"0" cold.
Old 11-03-2015, 09:46 PM
  #54
Old School Heavy
I welded up the exhaust and took the car out for a bit tonight. She is very strong and RPMs to the moon. A ton of fun to drive. The permagrin is stuck on my face.
Old 11-04-2015, 06:16 AM
  #55
dogsballs's Avatar
Sound clip thru full pipes?
Old 11-04-2015, 04:37 PM
  #56
gnx7's Avatar
I assume it's a Compstar crankshaft also?
Incredible numbers.... can't wait to see some results at the strip compared to the previous setup.
It seems that most intakes peak and hit a wall at around 6700/6800rpm. Do you think this is cam profile.. or this is simply the airflow limit of the heads/intake combo? Needs more carb?
Old 11-04-2015, 05:09 PM
  #57
Old School Heavy
Compstar crank and rods. CP Bullet pistons.
As for peak power capabilities. The ultimate limiter is the intake tract (heads and intake manifold). The square port stuff has a lot more cross sectional area than the cathedral port, so its ultimate capabilities are much higher. The Dart LS3 heads raise that even further. Also, the square port Victor Jr. is a lot larger than the cathedral port manifold. This engine could easily peak even higher with more duration. A square port Super Victor would let this engine peak even higher.
Old 11-06-2015, 12:22 AM
  #58
03EBZ06's Avatar
you did good on that build. got a nice crack to the exhaust. Makes me want to put a carb on mine!
I see you have 8 coil packs. What is your computer setup or how to you control spark?
edit: just saw the first frame of your video.
Old 11-06-2015, 03:53 AM
  #59
flintwrench69's Avatar
But what about the weak low end dead spot that everyone says these square port heads have?
Old 11-06-2015, 06:40 AM
  #60
Old School Heavy
LOL! I have not found that yet. I have a tight nitrous converter and there is more power than the drag radials can handle on the street at anything below 40 MPH.
Quick Reply: “Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
