“Little Beast” 707 HP 403” Pump Gas LS2 with LLR & Dart LS3 Heads
#67
It ran 6.60s at 102-103 with high 1.4-low 1.5 60' times on motor first time out. I made a couple nitrous passes on a 51n jet tune. It went 6.20s @ 108-109 with mid to high 1.3 60' times. I did not get a chance to push it harder yet as I killed the TH200-4r not long after this video and I killed my first 4L80e. I need to pull it out to be fixed, but I am working on the house right now. With the 4L80e and the cage, I am betting the car is back up around #3750.
#70
Location: Coast of San Mateo County Between Pacifica & HMB
Steve,
What size headers and which brand did you have on the Dyno,
and are they the same as installed? Reason I ask is I have a
Some what similar LLSR, LS3 Head Engine Project at my builder and hope
To be on the Dyno in July. I have 1 7/8" ARH.
Thanks
Dan
Thanks
Dan
#74
Steve,
How is the tranny build coming along? What is ETA for back on the
Road?
Also do you happen to know/remember your intake valve weights,
Are they hollow or Ti? How about valve springs, pressures, and
Installed height, .050 before coil bind @ lift.
I have a somewhat similar LLSR Engine going together at my builder
Over the next ~60 days and just looking to compare/confirm to yours
Because your results were so Exceptional!
Dan
Road?
Dan
#76
Steve,
Road?
Dan
Road?
Dan
