Can a LM7 be a direct replacement of a LC9?
Old 11-22-2015, 11:47 AM
glanzergtx's Avatar
Default Can a LM7 be a direct replacement of a LC9?
I have a 08 suburban that had a Lc9 in it and the AFM lifter failed and ruined everything. I can get the LM7 motors pretty reasonable. Are they direct swap? i realize im going to a iron block from a aluminum. Also will disable the AFM. Which is fine. Anyone ever done this?
Old 11-22-2015, 11:52 AM
gnx7's Avatar
the main hurdle is if the reluctor wheel is a different tooth count.
Old 11-22-2015, 12:01 PM
glanzergtx's Avatar
I can only guess it is bc gen3 to gen4. from 28 to 58 or whatever it is.
Quick Reply: Can a LM7 be a direct replacement of a LC9?
