Anyone interested in LS2 part #s?
Old 06-12-2004, 05:13 PM
2000Firehawk's Avatar
I think that the 05 Trailblazer SS gets the LS2 also.....
Old 06-26-2004, 08:01 AM
WoodManZ's Avatar
Default 05 SSR with LS2 in our shop
As you can see from the picture this is a test mule an "unnamed company" here in north Fla. thrashes test vehicles. this particular test mule had an ls2 under the hood.Hopefully the production paint will hold up better.
Old 06-26-2004, 11:17 AM
soundengineer's Avatar
Originally Posted by natronathon
Since the LS2 intake requires a 90mm tb, will it not be a good mod for a relatively stock ls1? 90m seems quite large to run on a basically stock motor.
and If it gains anything....in any place...TQ/HP/Gas mileage??? I mean anywhere....
then it is a good mod to somebody.....
even if its not a economical mod its stil a mod that did something...no matter how small it is...
Old 06-28-2004, 09:04 AM
steve2001sh's Avatar
It might be more than you need, but unlike exhaust, too much intake doesn't really hurt anything, at least not by the time you get to the TB.
Old 06-28-2004, 09:13 AM
Come to think of it. Does anyone know the size of the MAF in the LS2? I might end up getting one of those instead of an LS6.
Old 06-28-2004, 11:39 AM
ChicagoPhil's Avatar
has anyone actually seen an ls2?
The Corvette Show Bloomington Gold was just here in St. Charles Il over the weekend & they had the new 2005 Vette there. NICE
It has the LS2 engine in it. Nicely put together...
Old 07-16-2004, 01:18 AM
wildchevy's Avatar
have you got a stock number for the LS2 block yet?
thanks!
Old 07-16-2004, 10:30 AM
99SeanWS6's Avatar
Old 07-16-2004, 09:19 PM
CanuckSS's Avatar
Somebody must be able to give an estimate when the ls2 intake will be available. I am getting antsy!
Old 07-30-2004, 03:13 PM
Cerebrex's Avatar
I'm pretty sure the FAST 90mm will hook right up... that's the way it looks anyway.
Old 07-30-2004, 03:57 PM
Scalpel's Avatar
Originally Posted by WoodManZ
ls1 and ls2 use the same(junk) headbolts. looks promising for ls1 coversion.
The headbolts aren't junk. They're TTY bolts so they can only be used once after they've been stretched to their spec.
They work on all the other LSX applications (that aren't pushing huge FI cylinder boost pressures) so I'm curious as to why you feel that they're junk?
Thanks.
Old 07-30-2004, 05:02 PM
  #32
02RedHawk's Avatar
Did anyone else here know that a 05 GrandPrix was getting an LS4 5.3m.
I found out when I crossed over the ls2 cyl head # and, it is the same as the ls4.
Life around GM continues get more and more interesting
Yep. 5.3 V8 for the GP. Gets a new steering wheel design that I was working on.
Old 07-30-2004, 09:22 PM
  #33
BigTex's Avatar
Very interesting. So the aluminum 5.3 gets the LS6 cylinder head. I assume they will just take some of the dish out of the piston to make up for the added chamber volume.
Old 07-31-2004, 03:38 PM
  #34
NoOne's Avatar
What about a block part number?
Are service blocks going to be available?
Old 08-01-2004, 07:10 PM
  #35
turbo'd stang's Avatar
I too was wondering what the block number is and price!
Old 08-03-2004, 01:15 AM
  #36
Scott Turvey's Avatar
The MAF is 90mm also, at least on the 'vette.
Old 08-04-2004, 10:47 AM
  #37
88SS LS1's Avatar
Just to let every one know the estimate cost for customers on the new LS2 intake will be list for $357.86 depending if the dealership marks them up or not.
Old 08-04-2004, 10:59 AM
  #38
88SS LS1's Avatar
Here's some prices on these list price
for the LS2
Camshaft part # 12574519 $330.00
intake manfold 89017648 $357.86
LS2 engine 89017654 not found
intake valve 12563063 same as ls1 $22.60
polished rear wheel 9594349 $619.51
valve springs 12586484 same as ls6 $9.02
Old 08-04-2004, 11:05 AM
  #39
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
for the LS2
Cool , how about the Throttle body....
Old 08-04-2004, 11:13 AM
  #40
88SS LS1's Avatar
got the part number
Quick Reply: Anyone interested in LS2 part #s?
