L76 rod knock or lifter noise?
So my wife just fired up her 09 G8 GT and it was making what sounded like a rod knocking and filled the garage with black smoke out the exhaust. I ran out to the garage and told her to shut it off. I then checked all the fluids and it's full. Oil has no coolant in it that I've seen on the dipstick. Going to go drain the oil to make sure though. I just fired it up just now so I could hear the noise myself and the knocking is gone but the valvetrain sounds loud way louder than the normal lifter tick. I have no experience with the L76 yet, so was hoping someone has some suggestions on possibilities to check out besides drain the oil and check it and doing a compression check.
pull off the valve covers and see if you have any unusually loose rockers.
