CP Pistons. Not to familiar w/these.
Thanks. Those are definitely some good looking pistons AND thats what I'll be using, but I suspect at a lower CR in case the head I use gets swapped. What kind of power at the wheel did you end up with?
Still havent put the motor in the car. made about 78o on the engine dyno. switching out the lifters and rockers to shaft mount and short travel race lifters. i was maxed out with the rockers at the lift my cam operates at. the hydraulic roller was still spinning and making power all the way to 7800, there was no drop off so i want to take the rpms higher
