Questions on Lsa block
I picked up a nice Lsa short block and wondering about a few things...
Thinking of selling the rotating assembly and keeping the block and building a stroker....
Should i only stick to 415--416ci. or can i go bigger with this Lsa block...???...no power adder ...all motor....so I'm thinking higher compression...
i do have GMPP cnc Ls3 821 heads..Ls3 Super Vic 4500 carb. intake manifold with Prosystem 4500 carb...
Has anyone taken the oil squirters out and put set screws in ??
Redtan, can you explain why more than 4"
stroke cuts down on reliability, longevity.
I have a 4.100 stroke and wondering how much
I screwed up by going that route. I have asked
before and just wanting more opinions. Thanks
Piston manufactures have gone a long way in designing pistons for long strokes in stock liners and have greatly improved on this issue...but the liner length still remains a limiting factor. 4" strokes have been ok for lots of miles in plenty of applications. Past that though it starts to get less and less reliable over the long term, especially with 4.1" and 4.125" strokes.
It's not the end of the world with a 4.1" stroke, it's just that you'll burn more oil and probably wear out some engine parts quicker than the same engine but with a sub 4" stroke.
<a href="http://s51.photobucket.com/user/bigcowl-imp/media/ls9%20block%20002_zpsjjylya90.jpg.html" target="_blank"><img src="http://i51.photobucket.com/albums/f393/bigcowl-imp/ls9%20block%20002_zpsjjylya90.jpg" border="0" alt=" photo ls9 block 002_zpsjjylya90.jpg"/></a>
Doesn't really make sense to me either, especially since in stock form it's only 3.622 stroke, unless the designed it with the aftermarket world in mind because of what the engine is put into. But I do know GM wouldn't say it's possible unless it is.
The 2015 and 2016 catalog both say the same. LSA and LS9 max stroke of 4.50. Block part numbers 12623968 lsa and 12623969
