Help on LS3 Cam choice
Hello,
I am looking at purchasing a BTR cam for an LS3 short block.
Car: 3rd gen F-body
Trans: T56
Gear: none but looking at 3.90-4.11 (leaning towards 4.11)
Heads: Stock Ls3 with BTR .660 platinum springs, BTR pushrods. CNC could be in the future.
Intake: LS3 Looking at getting a 92mm cable TB.
Headers: 1 7/8 hooker long tubes
Power goal: At least 450, but good mid range is important as this is mainly a street car.
Looking to maintain good drive-ability. This is a street car that will maybe see 1 drag strip and 1 or 2 autoX a year for fun.
Thanks!
Car: 3rd gen F-body
Trans: T56
Thanks!
Brian knows his ****. There is 3 sponsors I'd consider in spec'ing a rect. port cam. Patrick G, BTR and Martin Smallwood of Martin SmallwoodraceDevelopment.
I PERSONALLY would use Patrick G. It costs either $25 or $50, but its spec'd to your specific car and goals. Martin will do it for free when you buy his cam. BTR probably does too.
I always point people towards Martin Smallwood for all things cam related. The others mentioned definitely can spec you a decent cam as well. I doubt you need anything as large as the comp cam mentioned, but I'm no expert. Good luck and let us know what you end up with.
Cam Motion 233/246 .630/.605 113 +3 LSA is what I put in my ls3 this weekend.
Caddy with exhaust - YouTube
Spoke with BTR and we narrowed it down to two options. I am looking at either of these cams.
225/238 .612"/.585" 113+3
229/244 .615"/.595" 113+4.
Not sure. Thoughts?
Not sure. Thoughts?
I'm looking at going 1 7/8 long tube headers into a Y with cut out and then muffler then SLP over the back. Would like it somewhat tame without the cutouts open I do frequent 5 hour one way trips in it and want to be able to hold a conversation.
I like the cam choice. And I understand if it's a budget issue with the exhaust, but if you can at all afford it, go with the duals. You can make a true dual set-up plenty quiet enough to drive and hold a conversation.
The reason why I was planing to go with the route I mentioned was because I have an SLP LM1 cat back without the resonater already from a 2000 Camaro I bought for parts. My car is currently a bone stock 3rd Gen. Buying the LS3 drained all the money. Time to start saving again and start the swap.
**** an SLP loudmouth is just as bad as true duals lol. I'm actually starting an LSX swap on my 3rd gen as well and I have a stock exhaust/muffler from a 4th gen sitting on standby just for that reason. Just gonna have to run a cutout and be happy with it. Although I'd rather run duals, I live in California so gotta keep the noise down as much as I can.
