LS7 Dry to Wet Conversion
Its been in a magazine before. Just try to GOOGLE it.
I'm building a wet sump LS7 to fit in a DSE frame with the set back mounts. The set back mounts allow the C6 oil pan to fit. I like the C6 pan over the F body for oil control.
The GMPP catalog has a windage tray for 4" stroke. The other parts are over the counter for C6 wet sump LS3, including the balancer.
I had my crank cut, but SD sells a spacer if you are not disassembling the engine. If you use the spacer you use a LS7 bolt, LS3 if not.
http://www.superchevy.com/how-to/engines-drivetrain/1512-how-to-convert-an-ls7-wet-sump/
Hope this helps.
Hope this helps.
There are not too many mounting options for tanks, stock or otherwise in a f body engine compartment without fabrication and or putting the tank in a non ideal location behind the fender.
The tests I've seen have shown increased HP for wet vs dry sump.
Only a fool would put a used oil tank on a new engine. Who knows what's hiding in there?
My guess for the slight hp increase is from the 2 stage to single oil pump ( less power to turn it) The hp i have a seen can not be felt and no gains on a track
I faced the same dilemma and decided to go wet sump.
Unfortunately what is cheapest might not be the easiest.
