Need help picking a heads and cam combo for a boosted LQ9
LQ9 is 9.5:1 compression with a forged bottom end. It will be a boosted high horsepower setup.
What would you guys recommend for heads and a cam? I'm wanting something with some lope. I will be running a 3000 stall converter in a 4L80E. Not sure about gearing.
It will be running 14-16 lbs of boost in a turbo setup.
I was looking at ported LS3s but some of my friends suggested there might be better choices for a boosted application.
850rwhp with either cylinder head isn't going to be a problem. I would recommend getting in touch with one of the vendors here to see what they recommend. Texas-Speed, LJMS, BTR, and Cam-Motion are just a few that can get you fixed up.
