It may be "Just Another LS3 416 Stroker Build", but, it's MY LS3 416 Stroker Build! - Page 5 - LS1TECH
Thread Tools Search this Thread
Old 02-15-2017, 02:31 PM   #81
psychosid30's Avatar
Now for what I consider my biggest accomplishment in the last couple of months - I finally managed to get someone over to help put in my Wolfe chromoly roll cage.
I'm quite sure there are several little things that I've forgotten about, but, that covers most of the important stuff. This weekend I'm going to try and get the last couple of things in the engine bay and under the car finished completely, start adding fluids, bleed the brakes, dye the dash, start applying fat max to the interior, and maybe even tackle rebuilding the steering column with larger tilt pins to remove some of the play out of the wheel.
psychosid30 is offline   Reply With Quote
Old 02-15-2017, 02:57 PM   #82
themealonwheels's Avatar
FINALLY!!! Looks good...
Also, that throttle cable bracket is badass, hope you took dimensions or kept a template to fab more! We will powder and ship, taking orders now lol!
themealonwheels is offline   Reply With Quote
Old 02-15-2017, 03:00 PM   #83
Also, looking at the intake pics, I'm surprised you didn't depin the electrical connectors to paint them black or even silver...
And I'm pretty sure you're the king of zip ties! I will refer you to a certain white 2002 z28 camaro where you blew a whole sams bulk case of zip ties on your wiring...
Old 02-15-2017, 03:13 PM   #84
I'm still thinking about it after we get it running...
As for zip-ties - there's a difference in using it for organizing and using one to hold on your GO-FAST CABLE!!
Old 02-15-2017, 03:21 PM   #85
Just figured out how to resize images. My hosting site changed a few things up. Going to do that now...
Old 02-15-2017, 03:54 PM   #86
Oh yeah, forgot to mention. When they say 89in/lb on the starter power wire, they mean 89in/lb!! Old school tightening by feel didn't work!
I had to order a new starter solenoid...
Old 02-21-2017, 11:30 AM   #87
Holy underestimating Batman! I was able to work on the car most of the weekend, but, didn't get as much done as I thought I would. I did get the dash prepped and the first couple of coats of dye on it (will take pics this weekend). I also got the fat mat installed. I needed this done and out of the way before I ran the rest of the interior wiring and installed the dash. It took almost 2 whole days to get it installed the way I wanted.
The only area I didn't do yet is the doors. I still have to pull the door bars and jamb it out for the color change.
I would have gotten more done, but, I ended up going to the Foreigner concert at the Hard Rock Casino and, well... Sunday was a bust.
Hopefully I can line up help this weekend (ahem, Loren...) to help me with the final wiring to the auto shifter. I probably shouldn't try it by myself. There's no telling what it would do if a color-blind person does all that wiring...
Old 02-21-2017, 03:12 PM   #88
Looks like you didn't do anything over the weekend... just stole the foil from your kitchen!
No promises, man, bundle of joy and all. Maybe, Mardi Gras.
Old 02-21-2017, 05:50 PM   #89
Looks liked the local Dynamat supplier got his inventory wiped out here....
G Atsma is offline   Reply With Quote
Old 02-22-2017, 07:25 AM   #90
Quote:
LOL! yeah, I tend to go overboard when I do things. This whole job started out as a simple LS1/T56 swap. I had no plans to go stroked LS3, auto, full tubular, powder-coating everything, or even interior/exterior color swap. Things just sort of steamrolled.... My wife has no idea how much we have in this car. She thought it was around 10k. I sorta let it slip we were over that. Didn't let her know it was probably about double that...
P.S. It's actually FatMat. A whole lot cheaper for the same thing, without the logo on it. After hearing Loren's car before and after he installed this stuff, I couldn't build this thing without doing it. It is night and day between the noise level after install. Also got rid of a lot of vibration and squeaking.
Old 02-22-2017, 07:32 PM   #91
blk00ss's Avatar
lol I couldn't sleep at night knowing I had that extra 100lb of crap riding around with me lol. Noise be damned.
blk00ss is online now   Reply With Quote
Old 02-22-2017, 07:37 PM   #92
FatMat..... good to know. Thanks!
Old 02-22-2017, 08:17 PM   #93
Quote:
If he were that worried about weight, he'd lose some by working out lol!
J/k, he actually is a friend despite what Internet me may lead you to believe...
But seriously, he's running my old true dual dumped setup. The fat mat is practically required for sound and rattle attenuation, and he already lost weight by not running it out the back with full size mufflers. It's not 100lbs of weight avoidance, but it's a good chunk.
Old 02-23-2017, 01:55 PM   #94
FatMat weighs .31lb/sqft. So, even if I use the whole 100sqft I'm only adding 31lbs.
Besides, I'm not worried about the weight. This car will be used primarily on the street. I'm going to have a full interior, A/C, Power steering, and a full stereo system complete with 10" sub. The days of me removing creature comforts for that extra .1sec in the quarter are WELL behind me! Like Murtaugh said in Lethal Weapon "I'm too old for this ****"
Old 02-23-2017, 03:41 PM   #95
bbond105's Avatar
Psychosid what mil thickness of the FatMat did you use?
bbond105 is online now   Reply With Quote
Old 03-01-2017, 07:20 AM   #96
Quote:
I'm using the 50mil FatMat - no logo.
Old 03-01-2017, 12:22 PM   #97
bbond105's Avatar
Thanks for the info.
Old 03-06-2017, 12:07 PM   #98
Default 6MAR17 Update
Well, I got a little more done to the car. I ripped the steering column apart and replaced the hinge pins with oversized units. That actually got rid of most of the lovely Camaro "death wobble" in the column.
Watch out moving the column around during disassembly or this can happen. Luckily I found all of the ball bearings and it went right back together.
I have two videos showing the before and after difference in the wobble, but, I'm going to have to look up how to insert videos.
I also got the jambs ready for color. I know this seems a little out of order, but, I want the jambs finished before I put the dash in. It makes it easier in the long run. Well, as you can see from the pics, priming out the jambs sort of snow-balled. It just didn't make sense to me not to go ahead and prime the rest of the car. I've still got a few nicks to work out, but, it's about 75% ready for paint.
Yes, I zoned out and forgot to remove the locks. My ignition switch is a bit worn out anyways, so, this will force me to go ahead and pick up a new lock set for the car. Maybe I did it subconsciously?
I also got the transmission shifter wired up correctly. I found out that you can't just follow the guides you find on this site blindly if you start with a V6 car. Most people do the smart thing and start with a V8 car! I had to move a couple of wires around to get everything to line up correctly.
Next weekend I'm hoping to wrap up painting the jambs and finish dyeing the dash black. I'm also hoping to get the brakes bled and finish getting all of the fluids in the vehicle except the oil.
That's it for now. Until next time...
Old 03-06-2017, 12:17 PM   #99
Do you still have door bars?
Old 03-06-2017, 12:35 PM   #100
Just one. Someone's wife gave him a curfew and he had to leave before he finished up the other one...
Related Topics
Thread Thread Starter Forum Replies Last Post
403ci Ls2 Stroker Nitrous Build 455GTO Generation IV Internal Engine 48 03-04-2017 01:25 PM
My 90' Fox Coupe LS3 418-N20 Swap t_rod27 Nitrous Oxide 52 08-27-2015 04:00 PM
1987 Camaro Z28 Turbo 5.3L 4L80e jay_rich Forced Induction 29 07-31-2015 08:31 PM
455whp 10-second 1995 Pontiac Trans Am, fully loaded - $9.5k- REDUCED RamAir95TA Vehicle Classifieds 102 05-07-2015 06:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
