Get your LS2 on the Street Today!
Old 09-06-2016, 05:13 PM
LivernoisMotorsports's Avatar
Default Get your LS2 on the Street Today!
Don't let your heads be the reason that you have to put your LS2 away before the season is over!
WE HAVE 2 SETS OF LS2 STREET SERIES HEADS THAT ARE READY TO SHIP OUT TODAY!
https://www.livernoismotorsports.com/product/LPP761100
These head packages are built around Livernois years of racing experience and combine all the knowledge of our extensive development background as well. This is how we're able to offer cylinder head packages that are unmatched in their performance.
5 axis CNC machined
Fully assembled
Custom CNC valve job
Custom ground factory intake valves
Custom ground factory exhaust valves
GM guides
Upgraded valve springs
Upgraded valve seals, retainers, locks
Old 09-06-2016, 05:26 PM
140K_GXP's Avatar
It would be nice if you guy would list the actual specifications for these heads.
Port sizing, spring pressures, type, max lift, etc. Combustion chamber size. Are these a ported factory casting or a Livernois casting.
Old 09-07-2016, 09:33 AM
All that it takes is a question...we use the factory casting.
Chamber size 64cc
Intake 3.200 tall 1.100 wide
Exhaust 1.400 tall 1.740 wide
Install Height: 1.820
Max. Valve Spring Lift: .690
Spring Pressure Closed: 150lbs
Spring Pressure Open: 382@.620 / 410@.680
Coil Bind: 1.100
Retainer Material: Titanium
Old 09-07-2016, 12:41 PM
"I MAID THEESE"
Mavn's Avatar
Flow Numbers? Seems like a lot for a 243 with stock valves IMO
Old 09-08-2016, 10:21 AM
Do you have a cam in mind? Blind flow data does not really provide any actual information or context unless we also have a camshaft in the equation.
Old 09-08-2016, 04:08 PM
140K_GXP's Avatar
Thanks for the info.
What is the intake and exhaust port sizing?
Old 09-18-2016, 10:18 PM
NorCalAnthony's Avatar
Curious about the intake/exhaust port sizing as well. Also, is the price listed on your website for a pair of new factory castings, seasoned cores, or customer supplied castings?
Old 09-23-2016, 08:25 AM
intake port 231.6
exhaust port 85.9
Quick Reply: Get your LS2 on the Street Today!
