2007 l33 camshaft rpm
I have a stock cam in a 2007 l33 and about 5200-5300 rpm it seems to level off noticeably. the engine is turbocharged but other than head studs and gaskets its all stock. just curious of the rpm limits of the cam, forgot it does have brian tooley .660 duel springs also.
Sounds like you found the limit of the stock cam...
Stock L33 power graph.
https://archives.media.gm.com/us/pow..._Silverado.pdf
Andrew
Andrew
Nose Pressure
My guess is that your lifters are being "compressed".
What is the nose pressure of your BTR springs ?
This statement is NOT to "demean" his "bit of kit", just a fair question ?
MY case, West Tech < Comp> cam, all failed, stock Z-06 camshaft, 1200 HP @ 22 .lbs. (circa 2006)
There could be a greater problem of concern ?
Lance
Lance
Lance
Lance
Andrew
Andrew
Lance
Lance
