New TSP roller tip OEM rocker
Old 01-10-2017, 11:29 PM
  #61
slogo's Avatar
This is the kit I have.
Old 01-10-2017, 11:52 PM
  #62
Mercier's Avatar
I am thinking that and this:
https://www.briantooleyracing.com/ho...ve-covers.html
Old 01-11-2017, 08:23 AM
  #63
KCS
Moderator
KCS's Avatar
Originally Posted by KW Baraka
I'm talking about the Ultra Pro-magnums, part number 1676-16.
KW
Right, the Ultra Pro Mag rockers come in either a bolt down version or a stud mount conversion.
PN 1676-16 is the stud mount conversion but doesn't come with guide plates or studs. What did you end up using for studs and guideplates?
Old 01-11-2017, 09:53 AM
  #64
kinglt-1's Avatar
No, the polylocks are too tall, they hit the boss where one of the coil brackets
bolt on, oil fill valve cover, the other valve cover hits the metal baffle for the pcv
they might fit if you grind off that boss, and remove the baffle and grind.
That is what I figured.. What are you going to use for VC's?
Thx!
Old 01-11-2017, 09:56 AM
  #65
kinglt-1's Avatar
http://www.compperformancegroupstore...Category_Code=
Old 01-11-2017, 10:23 AM
  #66
KCS
Moderator
KCS's Avatar
Old 01-11-2017, 02:02 PM
  #67
kinglt-1's Avatar
I think that was the kit he is using unless I am missing something?
Old 01-11-2017, 02:16 PM
  #68
KCS
Moderator
KCS's Avatar
That was a different part number. He listed PN 1676-16 which is for LS3 heads and does not include the studs or guideplates. The one you have in the link is PN 16755-KIT, which does come with studs and guideplates, but its for cathedral port heads, not LS3 heads.
Old 01-11-2017, 02:55 PM
  #69
Jontall's Avatar
Thx!
Yella Terra has 10mm valve cover gaskets that might work: http://store.yellaterra.com.au/rubbe...-engines-10mm/
Old 01-11-2017, 03:40 PM
  #70
kinglt-1's Avatar
my mistake...I missed the part where he was using LS3 heads.
Old 01-11-2017, 05:43 PM
  #71
slogo's Avatar
Thx!
http://www.ictbillet.com/ls-series-v...-551641-3.html
Quick Reply: New TSP roller tip OEM rocker
