max? effort alum block build - LS1TECH
Thread Tools Search this Thread
Old 01-09-2017, 06:49 PM   #1
Default max? effort alum block build
Main bearing clearances....... What am I looking for???? Turbo app. LC9 block.
.0030 desired at operating temp, what is that clearance in my dining room......
rpm-inc is offline   Reply With Quote
Old 01-09-2017, 07:43 PM   #2
RixTrix's Avatar
Some of the aluminum blocked motors I used to build would not turn when they were cold.
Because the gaps opened up so much when hot I could not keep bearings in it.
And if that twists up your chonies get one of these http://www.hotheadheater.com
My buddy designed this to solve these problems.
RixTrix is offline   Reply With Quote
Old 01-10-2017, 10:50 AM   #3
LS1Tech Sponsor
Default Steel Mains/Al Block
HI, he is correct, the Housing Bore will GROW.
I try to get .002" though .0022" is more of the average size.
My first experience was a Ford Boss 494 Can AM engine, then a Seyler Ford Boss block.
We "shot" for .001" - .0015" as they had AL main caps !
Many machine shop's "boil" the block then check housing bores.
Lance
Pantera EFI is offline   Reply With Quote
Old 01-15-2017, 06:21 PM   #4
OK i'm confused.....a reputable sponsor recommends .0028-.0031 regardless of block material. Does gm use different bearings between blocks for oem apps???
Old 01-16-2017, 08:22 AM   #5
KCS
Moderator
KCS's Avatar
Quote:
Not really, but GM did go to a different coated bearing for the newer engines and some of the blower engines. I robbed a set of Gen V LT1 coated main bearings and LSA coated rod bearings for my turbo LQ4 build.
It's better to be too loose than too tight. In an aluminum block power adder application, .0025"+ seems to work fine on the mains. It really comes down to what parts and how much power its really going to have to endure.
KCS is online now   Reply With Quote
Old 01-20-2017, 05:55 PM   #6
Picked up the block today.
.0055 piston to wall clearance
Wiseco 3.80 pistons
Eagle rods
Stock polished crank
Balanced of course
King +.001 main bearings should get me where I need to be then?
I have a (cheap) dial bore gauge and am going to order a good micrometer tonight. I'll double check with plastigauge.
+.001 on king rod bearings as well?
Old 02-07-2017, 06:27 PM   #7
So I now have -
mitutoyo 2-3" .0001 micrometer
.0005 bore gauge
.001 increased clearance king xp bearings
Haven't touched the bore gauge in a few years and the collet that clamps the extension rods is missing....... Anyone know where to source one locally? I am wondering if a 1/4" rotozip collet would work? Its the 100$ish gauge that all look the same with the red case.
EDIT-Oh, also got the summit piston ring filer
Old 02-08-2017, 12:08 PM   #8
LS1Tech Sponsor
Default Main Bearing Clearance
HI, WRONG choice, use the King standard fit MAINS, not the +.001.
The mains with KING standard fit should be about .0022".
The rods with KING Race bearings should be .0032".
You may be able to buy the missing items at Harbor Freight.
Lance
Old 02-08-2017, 05:27 PM   #9
Lance
Well crap. Do you stock the bearings I need? PM me a quote to 60185?
Old 02-21-2017, 07:42 PM   #10
I need some help here.....
Due to the varying opinions on clearances, I decided to stick with one person's. I bought the bearings and wisecos from LJMS, so I am going with his. He suggests .0027-.0031 regardless of block material, and it usually takes the .001 extra clearance bearings to get there. He also suggested the std rod bearings. So I kept the +.001 mains and got the std rod bearings and a 10296 pump from LJMS.
This is my first time measuring clearances, and I am 91% sure I am doing it right. I bought a used mitutoyo .0001 mic. I don't know if it is 100% accurate, but should be good for zeroing the bore gauge.
I am still working with the crank, but did measure 1 rod journal. All mains were 2.5592. The one rod journal I measured is 2.100.
So my concern is the main clearance for now. Zeroing the gauge a few times, I am at .0039-.0041. I understand that is way too much if I am indeed measuring correctly.
I put a one of the stock used bearings in, and got .0022. I only measured one rod and got .0024. I don't think I am measuring wrong at this point.
Stock polished crank with 80k.
At this point, std king xp bearings would be .0029ish?
Old 02-21-2017, 09:42 PM   #11
gnx7's Avatar
Are you doing larger head studs? The stock 75-80ft/lb clamping load will be the weak link with trying to keep the heads down.
After that it'll be the crank over time
http://ls1tech.com/forums/attachment...-ls1-crank.jpg
gnx7 is offline   Reply With Quote
Old 03-11-2017, 03:52 PM   #12
With std king xp bearings I have .0023-.0025 on the mains. About the thrust....
I snugged the inner bolts to 15 ft lbs. Smacked the crank back then forward with a rubber mallet. Torqued the bolts to spec.
With a dial indicator on the crank snout, and prying fairly hard, I get .003 each way. So is that .003 or .006 clearance????
Old 03-11-2017, 04:25 PM   #13
I can move the crank .003 just pushing back and forth with my hands if that is relevant info.
Old 03-11-2017, 07:42 PM   #14
64post's Avatar
.0055 piston wall to piston clearance with Wiseco. forged
Pistons? That might rattle a bit when cold.
64post is offline   Reply With Quote
Old 03-13-2017, 07:37 PM   #15
Yes it may, but that wasnt my question. Any input on thrust clearance??
Old 03-13-2017, 08:37 PM   #16
KCS
Moderator
KCS's Avatar
I usually hit it back, then forward, then torque everything.
Clearance is total travel. If you push the crank back, set the indicator to zero, then push it forward and you get .003", then that's your end play. IMO, that's a little too tight. To fix it, I would use a piece of fine grit sandpaper on a granite tile, wet it with WD40, and with the two thrust bearing shells together, rub them on the wet sandpaper in a figure 8. I'll clean the bearings and check again, then repeat until I get .005-.007" depending on the application.
Old 03-14-2017, 04:30 AM   #17
Total travel with a big screw driver is .006. Moving it back and forth with just my hand is .003.
Old 03-14-2017, 08:19 AM   #18
KCS
Moderator
KCS's Avatar
That should be fine then. I'd run it.
Old 03-15-2017, 06:41 PM   #19
OK, great! Thanks! I am sure I will have a few more questions.
Related Topics
Thread Thread Starter Forum Replies Last Post
cam bearing clearance?? bugy Generation III Internal Engine 5 02-04-2012 08:36 PM
Valve guide clearance ? sting66cp Small Block & Big Block Chevy Specific 2 10-26-2009 07:30 PM
6.0 liter piston to bore clearance Goldstreak65 Generation IV Internal Engine 1 01-13-2008 02:46 AM
Too much bearing clearance? shortdog Advanced Engineering Tech 45 02-06-2007 09:26 AM
Bearing Clearance/Oil Pressure? SlickVert Generation III Internal Engine 8 06-07-2006 11:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
