Help me undestand cam timming
I'm installing a BTR stage 2 LS3 cam in my LS3 build.
BTR specs are, 225/238 .612"/.585" 113+3
Where does the +3 come into play?
The cam card from Comp Cams Says 110 ICL, installing dot to dot I get a ICL of 113, is this the +3?
+3* Advanced
Hi Troy, this is how I read the Card.
What I ask is an information request for your intended use ?
What is your intake valve weight ?
The C/L drop to 113 WILL increase engine torque at a HP LOSS OF A 116 C/L.
THEN the +3 Advance ?
You have the Hendrick head with BIG intake ports, good for Cup engines that REV to 9500.
Lance
Lance
