Bore aluminum 5.3 block to a 5.7??
Old 01-17-2017, 02:50 PM
30th t/a's Avatar
Default Bore aluminum 5.3 block to a 5.7??
Can you bore an aluminum '05-'06 5.3 out to a 5.7?
Im building a forged 347 and I dont know if I should go with a used LS1 block or a gen 4 aluminum 5.3 block and have it bored?
I know the newer 5.3s had very thick liners but i also keep reading that you can only bore a IRON 5.3 to a 5.7??...but I also see Thompson Motorsports and other engine builders using a bored out aluminum 5.3 block and labeling it as a 5.7
any help is appreciated
Old 01-17-2017, 02:56 PM
KCS
Moderator
KCS's Avatar
Sounds like you already know the answer.
Old 01-17-2017, 03:07 PM
30th t/a's Avatar
kinda - but I didnt know if there were certain years that this could only be done with and I also read that you could do it with an aluminum 5.3 but you need to install new liners....lots of conflicting info out there.
Old 01-17-2017, 03:35 PM
30th t/a's Avatar
http://www.hotrod.com/articles/max-o...for-ls-blocks/
Attached Thumbnails Bore aluminum 5.3 block to a 5.7??-ls-block-max-bore.png
Old 01-18-2017, 04:38 PM
pantera_efi's Avatar
Default Gen-iv 5.3 al
Hi, the LS-1 GEN-III block, "early', is VERY WEAK.
My method is a GEN-IV 5.3 @ 98mm +.003" @ .105" wall thickness.
Lance
Quick Reply: Bore aluminum 5.3 block to a 5.7??
