Proven 6.0/l92 cams that dont need flycutting
I have an 08 ly6 engine. I have a vic jr, 4150 throttle body, 1 7/8 headers into 3 inch exhaust. Car weighs roughly 3400, 6 speed wide ratio, 3.73-4.10 gear.
I am looking for a cam that will work well with the single plane intake and l92 heads. I dont want to flycut as i have a 408 in the works and just want to get this pig running. The main three cams i am considering are the
RCR 223/232 @ 111
CAM MOTION 227/235 @111
CAM MOTION 229/244 @ 112
Car will be 80%street 10%drag 10% autocross. 69 camaro chassis, so i prefer an aggressive idle
Thanks for the insight guys
RCR 223/232 @ 111
Location: Coast of San Mateo County Between Pacifica & HMB
I would speak with Kip @ Cam Motion and do custom
For $25-50 more. If L92 heads are stock I think +12* Negative
Split is the sweet spot for NA With a good exhaust
Which you have up to ~7K RPM.
My .02, 227*/239*, LSA 112-114 + 3* Adv
No expert, so ask Kip, his cam was AWESOME in my build.
Good Luck
Good Luck
My son is running the RCR cam you mentioned in a 09 G8 GT. He had his heads milled .030" and did not need to flycut. That cam sounds awesome and runs great. No surging.
RCR = Rick Crawford Racing. He uses comp cams cores and on request cam motion's cores. My son went with the cam motion cam.
