LY6 damper problem
LY6 damper problem
IM NEW TO THIS SO HERE IT GO'S
EVERYTHING WAS GOING GREAT UNTILL I WENT TO PUT DAMPER BACK ON I HAVE A INSTALLATION TOOL STATED OUT PUTING DAMPER ON CRANK THEN PUT TOOL ON STARTED PRESSING ON GREAT THEN IT LOCKED UP TIGHT! AND I MEAN TIGHT. IT WENT ON ABOUT 3/4 OF THE WAY.. I THOUGHT MAYBE ITS ON ALL THE WAY BECAUSE I DELETED THE VVT AND MAYBE THE NEW COVER WAS SHORTER THAT THOUGHT WAS WRONG SO I PULLED IT BACK OFF DID SOME MEASURING AND MADE SURE THERE WASN'T ANYTHING ON THE CRANK OR DAMPER THAT WOULD CAUSE IT TO LOCK EVEYTHING LOOKS GOOD SO I NEED YOUR HELP HERE .
Are you sure that the nut on the installation tool is doing the pressing and not the threaded rod moving into the crank? Proper use is hand-tighten the threaded rod all the way in the crank and then exclusively work with the nut. I would stack a few more washers/spacers under the nut and see if you get further. Also make sure the crank snout and pulley inside are clean, smooth, and free of any debris.
Good luck.
Good luck.
