Clearances ok or tight ?
Clearances ok or tight ? Na / possibly 200 hit. Melling HV/HP pump,7qt deep pan. 427 (sleeved LS3) spinning to 7200. Compstar crank rods/wiseco pistons/ total seal rings/ clevite bearings.
Mains .0018
Rods .002
Shirts .0045
end play .004
Rod side .020
1st.022 2nd.024 oil .028
Mains .0018
Rods .002
Shirts .0045
end play .004
Rod side .020
Rod Bearing
Hi, I would fit King Race bearings, rod only.
Your rod bearing is too tight.
You will NOT allow oil flow @ .002", enough to cool the bearing.
The better size is a .003" rod bearing measurement.
Lance
Lance
What would you set them to? Those are ERL's numbers ! Everything I've read is .002 min on mains .0025 ideal. Rods .0025 I was amazes how much the oil follow changes going from .0018 to .0025. Now that the news is out I'm really concerned about getting a quality assembly from them.
Moderator
The thrust is ok for a street car with a performance clutch or converter, but again, if you think you may end up with a little more aggressive setup, I would want more clearance, like .006-.007".
