Why do DOD/AFM Lifters Fail? - LS1TECH
Thread Tools Search this Thread
Old 03-03-2017, 07:34 AM   #1
89ROC-Z's Avatar
Default Why do DOD/AFM Lifters Fail?
I have a 2013 Silverado, 143,000 miles and it developed a very loud valvetrain "tick" all of a sudden on the road.
Knew it was DOD or rocker related, so after taking the passenger valve cover off I found the #4 intake pushrod was loose, and ~.5" lower than the rest. Rockers, and rocker stand all in good shape.The valley cover seals looked good.
So-why do they fail? Engine oil changed very regularly, very clean internals. Truck never beat on.
I'm thinking of just changing out the 8 DOD lifters and hoping it's good for another 100k. What GM part number should I use? I hear GM updated the lifters to a more reliable lifter.
Thanks
89ROC-Z is offline   Reply With Quote
Old 03-03-2017, 08:38 AM   #2
Simply put, it's a more complicated lifter than the "regular" ones. And the more complicated or complex something is, the higher the likelihood is for failure. Maybe a form of Murphy's Law?
G Atsma is offline   Reply With Quote
Old 03-03-2017, 08:54 AM   #3
I've dealt with two different trucks failing, both were oil pressure to the AFM lifters. First one is my truck with a partially blocked filter screen and possibly a leaky VLOM. Second one was a friend's truck that ran low on oil due to crazy oil consumption issues (another awesome AFM side-effect). Both instances seem that oil pressure was lowered in the AFM system.
I think your best case is to replace all the AFM lifters and the VLOM and make sure the filter screen under the oil pressure sender is clean. Then check your oil often to make sure you're not consuming a lot. Or just disable AFM in the computer and deal with slightly lower fuel economy.
jamesr is offline   Reply With Quote
Old 03-03-2017, 09:08 AM   #4
I doubt you'll notice any real fuel mileage difference. My wife's Suburban has DOD and the only times I've seen it in 4cyl. mode is while coasting and RARELY at steady cruise. Being a heavy truck like this with a 5.3L, it does not surprise me being in 8cyl. mode about 95% of the time. I'd rather it didn't have DOD because of the extra complexity.
Old 03-03-2017, 03:24 PM   #5
spy2520's Avatar
I've replaced DOD lifters atleast 3 times on GM, and once so far on a dodge.
spy2520 is offline   Reply With Quote
Old 03-04-2017, 05:09 PM   #6
89ROC-Z's Avatar
Quote:
I agree. I should get the heads off tonight to see what the lifters are actually like.
I'll have to check that screen. I did notice all of the bolts for the valley cover were loose..... so loose that some oil was starting to leak through the gasket.
I'd delete it all but it needs to be back on the road asap. Hoping the cam is fine so I can put in 8 new DOD lifters and button it back together.
Quote:
At least it's not a terrible job to do, as long as they don't fail far from home.
Old 03-04-2017, 05:10 PM   #7
89ROC-Z's Avatar
So far the most frustrating part is getting the exhaust manifolds away from the head to remove that row of bolts... manifold to exhaust flange is damn tight
VALVE LIFTERS - GM (12645725) should be the part number i need, correct?
Old 03-05-2017, 07:36 PM   #8
spy2520's Avatar
Quote:
Lifter ate the cam on the dodge.
Old 03-08-2017, 09:12 PM   #9
89ROC-Z's Avatar
Everything is cleaned up and ready for new parts when they come in tomorrow and Friday.
I was thinking................... if this happens again, what's stoping me from tuning out DOD/AFM in the PCM and running a longer pushrod on the lifter that failed?? I would think the failed lifter would stay pretty static as far as pushrod cup height. I could measure how long of a pushrod I would need and that cylinder should operate as normal then, correct?
Related Topics
Thread Thread Starter Forum Replies Last Post
LS4 AFM Lifter failure? Loganjstone Generation IV Internal Engine 2 05-07-2016 08:43 AM
2006 GXP LS4 DOD delete help. MADDYSMODS LS4 Performance 54 07-10-2015 10:27 PM
intake swap with dod tuned out 83monteLS LS4 Performance 2 05-08-2015 06:16 PM
AFM/DoD Delete sommmatt Generation IV Internal Engine 11 02-08-2010 05:53 PM
DOD, VVT and AFM Proper Removal Questions - Popping Back Through Intake Issue Mike Norris Generation IV Internal Engine 7 09-29-2009 01:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
