LS Stroker ideas
LS Stroker ideas
Im new to this anyway Would it be a good stump puller if i built a 447CI LS
4.155 bore with a 4.125 crank and LS6 heads for the lower rpm torque with an LSX or LS Next block? in a mid 90s 3/4 ton chevy pickup with a 4l80e Behind it?
I'd just do 4.125x4.00 with TEA TFS 235 with Pat G cam
Is it worth more to you to look old style than have the efficiency of coil-on-plug ignition? Why do you think everyone building cars has abandoned them? Yeah, BIG disadvantage using a distributor....
Truck go be used as a tow rig ?
