LS2 Build need help
Old 03-07-2017, 08:12 AM
motodad279's Avatar
Default LS2 Build need help
I've got a short block with rotating assembly I would like to keep stock bottom end is it possible to get 500 at flywheel I'm looking for a semi daily driver and want to run pump gas I'll need Heads,Cam and intake.What should I be looking for.
Old 03-07-2017, 09:14 AM
Tuskyz28's Avatar
500 horse at the flywheel is easy to have.
Cheapest way... get a set of 243 heads then send them off to TEA or Advanced Induction.
Get a cam matched to the heads depending on who port the heads. Brian Tooley , Patrick G, and Martin Smallwood comes to mind..pick one.
A LS6 intake will get you there to meet your goals the cheapest.
Long tube headers are a must.
Otherwise if you got some more cash you can get close to 600 with a aftermarket head such as a AFR or TFS head with a Fast intake.
Old 03-07-2017, 11:00 AM
motodad279's Avatar
This engine will be installed in a jeep I will not have room for long tube headers can i make LS3 manifolds work I would love over 500 for a little more money as long as I can run pump gas
Old 03-07-2017, 11:23 AM
Tuskyz28's Avatar
I understand. I would try getting a the cylinder heads with a nitrous exhaust port. Help get some air out the motor. Also contact Pat G for a custom cam. You GO NEED A GOOD BIT MORE OF EXHAUST DURATION THAN NORMAL.
What's your budget for cylinder heads ?
Old 03-07-2017, 01:03 PM
motodad279's Avatar
I would like to stay below a grand
Old 03-07-2017, 01:58 PM
Tuskyz28's Avatar
I'm thinking Texas speed have a cnc program for a 750 dollars or so.... That's you sending them your cores.
Old 03-07-2017, 02:01 PM
motodad279's Avatar
I will check and see or try and find some someone is selling
Old 03-08-2017, 10:49 AM
farmington's Avatar
is this for an off-roading jeep? If so, I'd be more worried about bottom end torque than hp
Old 03-09-2017, 04:09 AM
Kamaro's Avatar
With a set of small PRC 227 heads and a tiny 223/229 cam and a FAST intake I was able to achieve 445rwhp and 440rwtq, which means about 530hp at the crank. The short block is untouched LS2 in a 2006 GTO.
The best thing about it is it sounds and drives like a stock car.
Old 03-09-2017, 08:27 AM
motodad279's Avatar
It will be more street driving but yes I do go off road I was thinking of putting the 92mm fast intake on it.
Old 03-09-2017, 08:29 AM
motodad279's Avatar
Here are the cam specs Texas Speed recommended 232/234 .600/.600 112
Old 03-09-2017, 08:19 PM
motodad279's Avatar
I'm looking for a good cam and intake combination I was thinking of finding intake from Trail Blazer SS to give a littler more torque
Quick Reply: LS2 Build need help
