LQ9 with LS3 Heads NEED CAM HELP!!! PLEASE - LS1TECH
Thread Tools Search this Thread
Old 03-16-2017, 04:01 PM   #1
Question LQ9 with LS3 Heads NEED CAM HELP!!! PLEASE
I have a 1987 Cutlass with 3.73 gears, a 2003 LQ9 with the matching 4L60E tranny. I also have a set of LS3 head that will be port and polished that i would like to put on my LQ9. I would like to know if the cams listed below will work for a DD (at least 80miles/day) or if you would recommend a custom grind. Also what Stall Converter would be best for a DD with the cams below. Will a dual spring with the max lift of .650 work? i would like to see around 475whp with at-least 14mpg if possible
Xer 273HR (224/230 .581/.588 114) or
LSr 273Lr HR12 (223/231 .610/.617 114+2)
Which of the 2 cams listed best for a DD lq9 with ls3 Heads?
Stall size?
Valve Spring size?
Obnes Saintelot is offline   Reply With Quote
Old 03-16-2017, 09:16 PM   #2
1. Either cam will work fine as a daily driver.
2. A set of .650" springs is exactly what I'd use. Specifically, I'd go with a set of PAC 1221 springs. --->> http://www.racingsprings.com/LS-Engi...-1221/Item/766
3. A good 3000 stall converter.....I like Yank, Circle-D and Vigilante.
4. 475HP to the wheels is a bit of a stretch. I would think you'd see something around 430-450 and maybe 16 mpg.....depending on the nature and amount of your city driving.
5. Long-tube headers and at least a 2 1/2" duel exhaust are a must!
What conversion kit are you gonna use for the install? I went with Muscle Rods. --->> http://www.brphotrods.com/products/7...cts/index.html
You'll probably need a costume made (for length) driveshaft......so be prepared for that possibility.
Best of luck!!
KW
KW Baraka is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Best Cam and Heads for lq9? Hotrodlanepdf Generation III Internal Engine 7 11-28-2016 01:08 PM
Turbo 6.0....will XER273=14 cam work ok? streetknight2 Forced Induction 4 12-05-2012 08:06 AM
5.3L 862's with TSP 224r? king of the wood New LS1 Owners - Newbie Tech 1 12-09-2011 12:03 PM
Which Cam Lobes to Use for 7000rpm+ LS7, w/ Stainless 2.205" Valves? GIGAPUNK Generation IV Internal Engine 16 03-12-2010 07:49 AM
Turbo/ cam match questions transaman98 Forced Induction 20 05-28-2007 04:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
