396 LS3 stroker
Old 03-16-2017, 10:33 PM
Derek Napier's Avatar
Default 396 LS3 stroker
I just recently acquired a 99 Z/28. At 1st, I was dead set on a forged turbo 5.3, then a pro charged 5.3. Realizing to build the way I want to build it, it would be a fortune, I came back to the old school mindset of more cubes. My question is has anyone used this setup in a street car? Currently the COPO Camaro's have an ls3 396 that's used in super stock. Sounds like a good package.
Old 03-17-2017, 05:51 AM
JosephIV's Avatar
Nobody is running this. Why? Because Scoggin Dickey, Texas Speed, Katech, Livernois, and many others have 408-418 iron truck block engines and 416-427 LS3 engines that are proven to make good power for less or the same money as the 396 you're looking at.
What's your budget? What's your goal? Does the car run right now?
If you want to run 9's in a play toy "street car" but you have a Pabst Blue Ribbon budget you'd be better off investing in an axle, suspension, tires, and a heads/cam/nitrous build before dumping 10 grand into an engine.
Old 03-17-2017, 09:43 AM
As of now, the car doesn't run. So I am looking at engine combos for it. The previous owner had a 370 in it and wanted to keep it. Street, track reliability are my goals. If it kissed the 10's, that would be great. But I need to think this out. I wasn't dead set on the 396. Just asking.
Old 03-17-2017, 03:18 PM
KW Baraka's Avatar
Originally Posted by Derek Napier
As of now, the car doesn't run. So I am looking at engine combos for it. The previous owner had a 370 in it and wanted to keep it..........
So you have no engine components at all right now?
OK.......if I were in your position right now, I'd go the Texas Speed turn-key route; they have several engines to choose from.
http://www.texas-speed.com/c-3188-as...d-engines.aspx
http://www.texas-speed.com/p-3570-ts...y-package.aspx
KW
Old 03-18-2017, 08:52 AM
pantera_efi's Avatar
Default Ls-396
Hi Derek, yes a LS-396 as GM "visioned"
This is WHY GM sells a LS-3 Rough Bore Block @ 3.930" for $900.00.
Buy that item, bore to 3.965" (good for ring, NO file fit).
Buy a Forged 4.00" crankshaft, rods, pistons.
Would you like my help ?
Lance
Old 03-19-2017, 10:37 AM
Lance
Im interested in hearing more about this setup.
Old 03-20-2017, 08:04 AM
Quick Ranger's Avatar
Lance
Lance, do you have a part number for that block? That would make an excellent block to bore to 4" and still have a lot of meat left while maintaining a strong block for a turbo setup.
Old 03-20-2017, 01:19 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah, I agree. The LS3 castings sometimes leave a lot to be desired. So getting a rough finish with that much cylinder left means you could run it up to 4" or 4.03" and still have a very strong block.
Old 03-20-2017, 07:34 PM
tug686spd's Avatar
[QUOTE=Pantera EFI;19566261]Hi Derek, yes a LS-396 as GM "visioned"
Lance[/QUOTE
Interested in hearing more about this block as well. Part number? Availability?
Quick Reply: 396 LS3 stroker
