LS7 3 Valve heads ???
Old 08-08-2004, 01:23 AM
Bink's Avatar
Default LS7 3 Valve heads ???
Any ideas, or guesses, of the .550" intake flow of the new 2006 3 valve heads? Has anyone seen data yet?? TIA.
joel
Old 08-09-2004, 07:30 AM
NoOne's Avatar
They way outflow the current LS6/2 castings, by a large number.
Haven't personally seen them but the info is good. Supposed to bolt with up with little or no mods to a LS2 block, maybe even Ls1/Ls6.
Old 08-09-2004, 09:30 PM
Adkoonerstrator
XLR8NSS's Avatar
I thought a reliable source posted flow in the 370cfm range for the 3 valve heads a while back. Lots of info flying around right now but, I am almost positive that info was from a VERY reliable source.
Old 08-09-2004, 09:41 PM
Juggernaut's Avatar
Well I have seen some flow sheets for a ported modular(4v) and they were in the 330-340cfm range @.500-.550 on a 3.550" bore. So with a better head design and the larger bore, XLR8NSS's number of 370cfm sounds about right. Just a guess though!
Ryan
Old 08-10-2004, 12:40 PM
Bink's Avatar
Thanks guys. This is what I was looking for!
Only a year to wait.........I'll sit tight with my LS6 heads until the 3 valves are available.
joel
Old 08-10-2004, 07:17 PM
52172's Avatar
Will the 3 valve heads bolt right up to a gen 3 block? Will we need to get an ls2 block? If we get an ls2 block and build a 402 will gen 3 cam kits work with a gen 4 block? I am trying to decide whether or not to build a 383 on my ls1 block or build a 402 with a ls2 block, but only if most gen 3 parts are interchangeable otherwise it will be a lot more money to buy everything new.
Old 08-10-2004, 07:40 PM
LS1derfull's Avatar
Not sure on most of what your asking but i do know cam sensor is moved to front of motor from the rear on LS1. So cams will be different.Knowing GM, 3 valve heads will have same coolant passages and bolt patterns as LS1.
Old 08-11-2004, 11:53 AM
LS1Tech Sponsor
hellbents10's Avatar
We can only hope they swap easily, could you imagine the numbers then. 10's all motor would not be a big deal and it would take so little work and a not so huge cam. Oh, I can't wait, the possibilities are endless. So who is going to hit 9's n/a with a stock cube ls2 or ls7?
Old 08-11-2004, 12:16 PM
eswolfgang's Avatar
I remeber in Automotive engineering magazine an article on the "LS7", had some data, imagine the new 5 speed auto, these 3 valve heads going on a 2002 camaro. I hope the new auto will fit.
Old 08-11-2004, 12:28 PM
Bink's Avatar
The LS2 in the vette has LS6 heads on it. So it would make sense that the LS7 heads will fit a LS1/6. The 2 intake valves function via a common rocker and single pushrod.
Hope..hope...hope...
Quick Reply: LS7 3 Valve heads ???
