LS2 and LS7 GM Parts Numbers List - LS1TECH
Closed Thread
Thread Tools Search this Thread
Old 05-22-2005, 12:30 PM   #1
ACW
ACW's Avatar
Default LS2 and LS7 GM Parts Numbers List
Decided to collect all the numbers scattered through multiple threads here. Please post additional part numbers, corrections, and requests in http://www.ls1tech.com/forums/showthread.php?t=201190
LS2 Part Numbers
LS2 bare block = 12568950
LS2 crate motor = 19156261 (formerly 12499750)
LS2 longblock assembly = 89017654
LS2 camshaft = 12574519
LS2 timing chain = 12586482
LSx lifter = 17122490
LS2 front cover = 12600325
LS2 rear cover (same as LS1/LS6) = 12572014
LS2 90mm throttle body with actuator (same as LS7) = 12570790
LS2 throttle body attachment fastener x4 = 11519971
LS2 throttle body attachment seal = 12576549
LS2 MAP sensor = 16212460
LS2 intake manifold = 89017648 or 12589181
LS2 intake to cylinder head gasket x8 = 12580833
LS2 intake manifold attachment bolt x10 = 12552344
LS2 intake manifold sight shield, LH = 12568998
LS2 intake manifold sight shield, RH = 12569246
LS2/LS7 valley cover = 12570471
LS2 fuel injector assembly x8 = 12569113
LS2 fuel injector o-rings (orange) = 89017587
LS2 fuel injector retainer clip x8 = 24503227
LS2 fuel rail = 12572174
LS2 fuel rail attachment bolt x4 = 12590276
LS2 front coolant tube = 12578838
LS2 rear coolant plugs x2 = 12563325
LS2 polished rear wheel = 9594349
LS2 valve springs (same as LS6) = 12586484
LS2 valve pushrod cover guide (lifter tray) = 12595365
LS2 cylinder heads (same as LS6) = 12564825
LS2 cylinder intake valve (same as LS1) = 12563063
LS2 water pump = 89017457
2005 Corvette C6 LS2 exhaust manifold, LH = 12569388
2005 Corvette C6 LS2 exhaust manifold, RH = 12576061
2004-05 GTO LS1/LS2 exhaust manifold, LH = 12563277
2004-05 GTO LS1/LS2 exhaust manifold, RH = 12563278
2003-05 SSR LH6/LS2 exhaust manifold, LH = 12567483
2003-05 SSR LH6/LS2 exhaust manifold, RH = 12567484
C6 LS2 oil pan (has shallow rear sump) (kit with bolts/gasket) = 12581810
C6 LS2 oil pick-up screen (same used on LS6) = 12558750
C6 LS2 oil deflector (same as used on LS6/LS1) = 12558189
C6 LS2 dipstick = 12570788
C6 LS2 dipstick tube = 12570787
SSR/Trailblazer 5.3L/LS2 oil pan (has front sump with hole for 4wd front axle) = 12579723
GTO LS1/LS2 oil pan (has front sump) = 12581209
2005 GTO LS2 PCM = 92180030
2005 GTO LS2 ECM = 12597883
LS2/LS7 spark plug wires = 89018058
LS2 flywheel = 12571611
Sources:
http://www.ls1tech.com/forums/showthread.php?t=203761
http://www.ls1tech.com/forums/showthread.php?t=216495
http://www.ls1tech.com/forums/showthread.php?t=244928
http://www.ls1tech.com/forums/showthread.php?t=282545
http://www.ls1tech.com/forums/showthread.php?t=207273
http://www.ls1tech.com/forums/showthread.php?t=254079
http://www.ls1tech.com/forums/showthread.php?t=240175
http://www.ls1tech.com/forums/showthread.php?t=181358
http://www.ls1tech.com/forums/showthread.php?t=278079
http://www.ls1tech.com/forums/showthread.php?t=431621
http://www.ls1tech.com/forums/showthread.php?t=347535
http://www.ls1tech.com/forums/showthread.php?t=506004
http://www.ls1tech.com/forums/showthread.php?t=476902
ACW is offline
Old 01-04-2006, 09:39 PM   #2
ACW
ACW's Avatar
LS7 Part Numbers
LS7 bare block = 12571246 or 17802854
LS7 crate motor = 17802397
LS7 500hp smallblock = 12578105
LS7 camshaft = 12571251
LS7 cylinder head (bare, without valves) = 12578450
LS7 titanium connecting rod = 12586258
LS7 intake valve = 12591644
LS7 exhuast valve = 12578455
LS7 intake rocker arm = 12579615
LS7 exhaust rocker arm = 12579617
LS7 rocker bolt (m8x1.25x34) = 11588791
LS7 pushrod = 12593344
LS7 valve spring = 12578457
LS7 intake valve lash cap = 12596509
LS7 fuel rail = 12569124
LS7 fuel injector = 12576341
LS7 intake manifold = 12569011
LS7 90mm throttle body (same as LS2) = 12570790
LS7 front cover = 12593546
LS7 crankshaft = 12568820
LS7 clutch and pressure plate kit = 24233650
LS7 engine oil tank = 12603281
LS7 oil pan = 12596689
LS7 oil pump = 12598212
LS7 auxiliary engine oil tank hose = 15210117
LS7 auxiliary engine oil tank hose = 15210122
LS7 dry sump tank = 12603281
LS7 outlet and inlet cooling line = 15210122
LS7 outlet oil line = 15210117
LS7 engine cover ('sight shield'), LH = 12574619
LS7 engine cover ('sight shield'), RH = 12574620
Sources:
http://www.ls1tech.com/forums/showthread.php?t=294013
http://www.ls1tech.com/forums/showthread.php?t=243257
http://www.ls1tech.com/forums/showthread.php?t=360249
http://www.ls1tech.com/forums/showthread.php?t=399809
http://www.ls1tech.com/forums/showthread.php?t=424127
http://www.ls1tech.com/forums/showthread.php?t=505717
ACW is offline
Closed Thread
Related Topics
Thread Thread Starter Forum Replies Last Post
Got cam/heads/rocker/machining questions about LS1, LS2, LS6? READ ME FIRST! Patrick G Generation III Internal Engine 0 08-25-2007 03:13 PM
cars for sale in fort myers bigbadblackws6 Florida Members 18 01-01-2007 11:57 PM
New to the Corvette group BlueZnR6 Corvette Performance 2 10-03-2006 02:01 PM
what happened to this thread? sgt0704 User Support & Resources 3 08-15-2006 12:33 AM
FS: motor, 2 tranny's, converter, misc local Houston WS6snake-eater Texas Members 0 06-24-2005 02:17 PM
Tags
12576341, 2003, body, gm, gto, ls2, ls2ls7, ls7, manifolds, oil, pan, pans, partsvlist, sale, screen, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
