Well the Autoworx 412 LS2 is in and roaring!
Old 08-10-2005, 09:47 PM
RAMPANT's Avatar
Thumbs up Well the 412 LS2 is in and roaring!
Here are some of the details:
- LS2 block at 4.0005 bore
- Eagle 4.100 crank
- Wiseco pistons, coated
- Comp Star rods
- all ARP hardware
- FAST 90 W/ NW TB
- ALLPRO head 2.08 1.60, 340@.625 on 4.0 bore
- Cam 242 / 250 .610 lift
- Pro Maganum 1.75 rockers
- Isky lifters
- Kooks 1 7/8 headers, ORY, with Maganaflow cat back
- Steel drive shaft 1350 yokes
- Moser 12 bolt, 3.73, Eaton HD 33 spline / spinning ZR1 17 x 11.0 c/w 315's
- McLoed Street Twin, steel flywheel
Well at the end of the day it layed down 519.22 rwhp thru the open Y pipe, cutouts not installed till tomorrow. I'm very happy.
Heres some pics and the graphs, the 511 is thru full cat back.
My old H/c compared to the new motor thru full exhaust.
I think it is a rather unique set up, that is making great street number, it idles pretty good. A few wish we went bigger on the cam but it feels great to me.
I thought a few of you may find this an interesting set up. I love it!
Rampant
Old 08-11-2005, 07:47 AM
Jim Mills's Avatar
Awesome #'s Dale. I hope we get some good weather on Saturday
Old 08-11-2005, 10:24 AM
vmax1500's Avatar
What's the actual flow # @ .600?
Old 08-11-2005, 11:09 AM
Jim Mills's Avatar
Yeah I'm thinking the same thing Andre... not much point in posting what they flow at .625 if you're never going to use it. I bet you would have made a ton more power with a bigger cam Dale
Old 08-11-2005, 11:15 AM
vmax1500's Avatar
It's hard to say from the graph, but it looks like the AF was leaner than 13:1... is this the case?
Old 08-11-2005, 11:26 AM
gtodoug's Avatar
I thought the same thing about the A/F. Hard to say when it's that small. I also noticed the numbers at .625(awsome by the way) but he is using 1.75 rockers. Wouldn't that bring his final lift specs to .6279411......? If so, he is taking advantage of it isn't he?
Old 08-11-2005, 11:33 AM
2001CamaroGuy's Avatar
so is the McLeod a borg and beck (looks like it)?
Old 08-11-2005, 12:02 PM
Jim Mills's Avatar
Yep he would be if that's the case... I forgot about the 1.75 Rockers.
Old 08-11-2005, 12:28 PM
Sharpe's Avatar
<Formula joke>That's one mean looking 6 cyinder!!!</Formula joke>
Old 08-11-2005, 12:53 PM
383ss's Avatar
results seem a little lot to me :shrug: I would personally have been expecting 550 or so. what compression?
hell of a nice setup anyway
Old 08-11-2005, 05:47 PM
RAMPANT's Avatar
Trust me Andre it is 12.8-12.9's all the way across I saw the same one with a better resolution. It is as close to perfect as it gets, always room for a little tweaking though.
Rampant
Old 08-11-2005, 06:01 PM
RAMPANT's Avatar
Yes it works out to .628 or maybe a little more I can't divulge all the secrets.
The Y pipe and cats are now installed and look great. You could do a chin up on this Y pipe now.
It was done by Master Perfomance in Brampton. He has a car to stomp you Andre a 3rd Gen running 8.40 on a 275 shot with 1.2x 60fts On a shake down all motor 10.7 at 117 testing the brakes at 900 ft. Lucky he is not a member. Oh yeah that is on a DOT tire.
Rampant
Old 08-11-2005, 06:03 PM
RAMPANT's Avatar
This is on 94 octane with low 11.xx compression. With an aluminum d/s,stock sized rims/tires and a 10 bolt I bet it would be 540ish. This is a very streetable cam. Some at the shop wish we had gone bigger, but I'm starting to dream of passing an emission test with a good tune. It smells pretty clean. In Ontario they are doing road side inspections and sniffer test, big fines.
Rampant
Old 08-11-2005, 10:30 PM
vmax1500's Avatar
Rampant
Looks good... there are ton of faster drag cars out there than mine is... fortunately, yours will not be one of them
Old 08-12-2005, 06:01 AM
RAMPANT's Avatar
I don't see how that is possible... the AF line is cleary in between 13 & 14... could you post a graph of the AF alone? This is easy to do, all you need is the dynojet file and the free viewer software which you could download off dynojet's webpage... it's important to make sure you get enough fuel esspecially with the desensitized LS2 knock sensors in an LS1 car!
LS1 knock sensors are used, different location. LS2 do not work, yet anyway. There have been a few that posted that this did pick up knock.
As for the graph that is just a scan of the print out. Trust me the top end is 12.99.
As for you having the faster drag car, without question. Mine is not a drag car not even close it has, Koni shocks, huge sway bars, full weight all factory options still installed, a real differential not a spool with only 3.73 gears and a M6 with a 3700+ pound weight with me in it.
Car feels great and is getting about 220 miles to the tank so far in stop and go traffic with quite a few little bursts of the load pedal . No oil appears to be used and smells quiet clean with the new cats installed. If it can make around 500 thru cats all pollution equipment and exhaust, that will be awesome.
Rampant
Old 08-12-2005, 03:19 PM
CHRISPY's Avatar
Looks great man congrats!!
Those rims/tires you dynoed on are what 65 pounds each? Big steel DS and 12 bolt. I think the numbers are great for the combo and compression.
stock waterpump too right? Do you have an UD pulley?
Not that it matters but with ALL The boltons and a stock 3.42 rear, DS, and rims/tires I bet the car would make 550RWHP on pump gas.
I bet you cant wait to race tomorrow!
Old 08-12-2005, 10:19 PM
RAMPANT's Avatar
Yes to all of the above, now check out todays pulls with the cats installed.
I'm impressed. these cats are worth every penny. The car smells clean to. I lost .4 hp woop tee doo. The car liked the rich program though, we leaned it out to 13.0 and lost 2 hp. It was over 70% humidty though and that is not correted on the dynojet.
What the MOE does not know won't hurt them.
Rampant
Old 08-13-2005, 06:15 PM
Mat
Mat's Avatar
Awesome numbers man! I bet yah that thing thumps yah in the **** when you mash to GO pedal.
Old 08-13-2005, 09:05 PM
RAMPANT's Avatar
Its ok, but I feel I need more
I need to learn how to get her hooked up, It showed no mercy to the MT DR's today.
Rampant
Old 08-14-2005, 12:10 PM
Gary98Z's Avatar
Awesome numbers ! Did you use Random tech cats? Do you think it'll pass emissions?
Gary
Quick Reply: Well the Autoworx 412 LS2 is in and roaring!
