Introducing the world's first LS7 F-body
#41
Originally Posted by MrDude_1
are the MSD coils there for any real reason? why couldnt/didnt you use the stock LS7 coils (or other OEM coils..)?
We could use the stock coils. MSD donated these to us for testing. They say they should help drivability and idle with high lift cams. ...yet to test on the street.
#42
cool.. id like to hear of some real testing done on them.
because i cant honestly find a good reason for anyone to buy them.
#43
Great job, very impressive. You said it ran on an LS1 computer. How did you do that, did you have to switch out the 58X reluctor wheel or did you guys find away around that problem without taking apart the motor? Do all vette 17X11 wheels fit on Camaros or did you have to do some modifications to the body? Again props to you and your team.
#44
I forgot to mention one of the best parts....it runs on a stock LS1 computer and can be tuned using LS1edit.
What did you guys use to tune this package?
#45
#46
#48
On this particular one we used EFI live V1 with Moates RoadRunner LS1 emulation hardware for realtime tuning.
Craig makes some killer stuff... im really surprised more people havent jumped on that roadrunner... its not talked about alot on here.
#49
#50
#52
Originally Posted by OmniRex
needs lowering springs...
Ok, to answer everybody's questions about the ride height:
The front is all new BMR everything and it's all out of wack because it hasn't been aligned yet. The rear has a moser which has a little higher stance in the back. After everything is aligned and settled we are considering springs.
#57
We swapped the 24x reluctor. We used AFS "ZR1" wheels. They fit after we cut out the bump stop.
That car is amazing, jealoussss. I know you post over at ffcobra on the GTM site, I guess you can understand how torn I am at this point. Build up the formy... or build a GTM?
#58
Originally Posted by FunkyTownFBody
Ditto on my Formy, cut the bumpstop and bracket off wit a torch and you should be good.
here i'll help:
BUILD THE GTM!
you're welcome.
#59
Jason,
OK, I'll be the first to ask... even though I do not own an F-Body...
I can't hard tell so I'll guess you used the factory LS7 oil pan
1) Did you test fit the LS7 with its factory pan in a factory f-body k-member?
2) Looks like ATI balancer. Does ATI now offer the correct offset balancer for the extended LS7 snout crank to allow use of factory F-Body accessories? Part number?
Super nice work guys...
Bill
Bill
#60
Holy **** I have not been on in a few days and this is what I missed!! If I only had the money to do something like this..I can't wait till the times come out for this along with some videos .. Keep up the good work and keep us updated
