LS2 Water Pump Flow #'s?
Old Jun 19, 2006 | 07:36 PM
05_GTO's Avatar
Default LS2 Water Pump Flow #'s?
Anyone happen to know the flow #'s for a OEM LS2 water pump?
I'm just wondering since I ordered a Meziere electric water pump (street version), which flows 55 GPM.
I've been told by the few that have used it it lowers the temps by 10-20 degrees even in the hot Az heat. I'm also wondering everyones thoughts on the Meziere?
Old Jun 19, 2006 | 08:12 PM
Steve1969LS1's Avatar
I ran it on my '69.. I will be running it on my '68 LS2 engine.. it's a great pump and with my '69 LS1 car I had zero cooling issues. Plus I could cool down the engine quickly between runs or when I wanted to work on it.
Old Jun 19, 2006 | 08:25 PM
05_GTO's Avatar
That is just what I wanted to see, you make me feel a lot better about my purchase
Old Jun 19, 2006 | 10:13 PM
DocEwww's Avatar
I think its a great investment with the heat soak issues experienced with the LS2s
Old Jun 20, 2006 | 03:39 PM
The Red Baron's Avatar
I thought the LS1 water pumps flowed 80 GPM and the LS2 flowed 160 GPM? Can anyone confirm?
Old Jun 20, 2006 | 07:08 PM
98Z28CobraKiller's Avatar
Restricted User
The reason that I may get one is just in case i throw a belt, my car wont instantly overheat and get mangled.
Old Jun 21, 2006 | 12:22 AM
05_GTO's Avatar
Noppers.
It took awhile but I finally found it. The stock OEM belt pumps flow 50-55 GPM. So the Meziere will work just fine . The best flowing street pump I could find is a Evans which flows 80 GPM... though it's belt driven.
