OK to reuse plastic oil galley plug?
I'm in the process of transferring over everything I can from my LS6 to my 402 LS2. The rear plastic oil galley plug (lolly pop) looks ok but has been on back order for 10 days now from the dealer. Looks fine, I think I'm going to reuse it, any reason not to? Also, has anyone else have to grind down the inside rear center rib in the vette oil pan to clear the windage tray after 1 washer was added? The pan will not sit on the rails until I did this.
Yep, everything looks good now, buttoned the pan and rear cover earlier and I'm dropping the notor in sunday. Now all I have to do is get the input shaft to fit into the pilot bearing and I'll be home free, hopefully. Thanks Dave!!
